Originally Posted By: CapriRacer
Just an FYI:
Rotating the tires is going to make things worse! Temporarily. You need to give the tires some time to wear a new pattern.
But be aware that you may not be able to wear the old pattern out enough to make a difference. After all, the new pattern is being worn on top of the old pattern and may not erase the old pattern.
That was my experience as well. My wife never rotated tires before I met her, so they had at least 20k on them. They were surprisingly silent on the highway. I decided to rotate them to try even out the wear, they were very loud at first, then slowly wore back to a more even pattern. I rotated them regularly for a while. It never got totally quiet again, but by the end of life, around 45k, they were much quieter, and the wear had evened out.
