Orbital Buffer - Boat Detailing
by PontiacHO - 01/24/20 10:32 AM
Do bolt threads grab at the same spot every time?
by motor_oil_madman - 01/24/20 10:26 AM
Amazoom Valvoline 5w30 deal
by volk06 - 01/24/20 09:28 AM
Forscan for Windows
by Donald - 01/24/20 07:30 AM
Group IV/V confirmed gear oils?
by metroplex - 01/24/20 06:34 AM
SATA Tools
by demarpaint - 01/24/20 05:10 AM
C-130
by Exhaustgases - 01/24/20 01:29 AM
Anyone Here Have a 9-Shot Rough Rider?
by ZeeOSix - 01/24/20 12:43 AM
Standard wix cartridge filter
by Bettez88 - 01/23/20 09:50 PM
Adaptive Driving Beam, Thoughts?
by Vern_in_IL - 01/23/20 09:07 PM
Chevron Delo XLE 15W-40 CK4 (semi synthetic)
by HDoilDude - 01/23/20 08:45 PM
Coronavirus
by buster - 01/23/20 08:04 PM
Used vehicle shopping
by 53' Stude - 01/23/20 08:01 PM
Carquest oil and filter deal.
by JTK - 01/23/20 07:35 PM
Anti seize vs silicone paste
by buck91 - 01/23/20 06:57 PM
UOA - 11 VW GTI 2.0T TSI - Purol 10w40 - 5k
by dubman - 01/23/20 06:33 PM
Old SG/CD Mopar Vintage oil useless?
by BBDartCA - 01/23/20 06:32 PM
Great Slave Lake
by 53' Stude - 01/23/20 04:57 PM
Went used car shopping today. So interesting
by WhyMe - 01/23/20 04:33 PM
Perseus, AJEwing, Mailman1995, DougCFL, Sayafi
70514 Registered Users
94 registered members (53' Stude, 2010Civic, AC1DD, 2011335d, 1978elcamino, 2015_PSD, 6 invisible), 2,134 guests, and 17 spiders.
Topics300,487
Posts5,177,112
Members70,514
Page 1 of 3 1 2 3
Fram Ultra -vs- TRD Synthetic comparison photos! #4046191 03/22/16 05:43 PM
sdude2k2000 Offline OP
For those that may be interested, I wanted to take some comparison photos of both the TRD oil filter and Fram Ultra for the late model 1.8L Toyota engine. This is the filter used in the current Toyota Prius, Corolla, Yaris, some Scion models, previous Matrix, etc etc. The OEM cellulose is allegedly 50% efficient at 20-microns... the TRD is 98% efficient at 20-microns... and the Fram Ultra is 99% efficient at 20-microns.
The TRD filter (made by Champion) is kind of a love:hate relationship. You'll notice the pleat spacing isn't very precise and they're pretty wavy right out of the box. In addition - the process of gluing/sewing the seam together resulted in some loss of media (see photo #2) - almost like a hole, but since it's on the glued seam - I'm not sure if it'd matter or not. The build quality is very solid (obviously) and the silicon gaskets at the top and bottom are an interesting addition unique to the Champion made filters (i.e. Amsoil), but they definitely add height to the filter as it's slightly longer than OEM and the Fram... so I'm not sure how that'd effect everything, but you'd want to watch your torquing and I could see it binding if you over-torque. It's also interesting that they decided to add a center-tube in the filter as all the 1.8L motors this would fit already have a tube built into the housing itself... and if you look at the last photo, you'll see the center tube actually results in less media depth -vs- the Fram or even the OEM cellulose.
The Fram Ultra build quality is excellent all around. They use the more traditional high-temp plastic endcaps. All pleats were evenly spaced and free of wavy distortion. The pleats also utilized the entire depth of the endcaps (versus the TRD which has the extra center tube). It's worth noting that the OEM cellulose filter is the same height as the Fram Ultra as well, so there should be no binding as you torque down the housing cap. Fit on the center tube was nice and snug, so there should be no slipping.
BOTH of them are Made in the USA! USA For what it's worth - I ended up using the Fram Ultra and will be returning the TRD.
Part Numbers:
Fram XG10358 - (purchased at Wal-Mart - $10.97)
Toyota PTR43-52090 (purchased at local Toyota dealer - $15.75)
'08 Ford Fusion SEL 3.0L
'15 Toyota Prius 1.8L
Re: Fram Ultra -vs- TRD Synthetic comparison (1.8L) [Re: sdude2k2000] #4046199 03/22/16 05:52 PM
B
BikeWhisperer Offline
B
I'd run the Fram, looks like a better constructed filter as well as being cheaper. It's interesting that they are made by the same parent company but clearly are not produced on the same production line.
2015 F150 XLT SCrew 2.7 Eco-Boost
5w-30 Magnatec, FL2062
2018 Ford Edge SEL Eco-Boost 2.0
5w-30 Magnatec, FL-910S
Re: Fram Ultra -vs- TRD Synthetic comparison (1.8L) [Re: sdude2k2000] #4046212 03/22/16 06:10 PM
H
HTSS_TR Offline
H
Agreed. Better quality or less is the real winner.
'00 MB E430
'04 Honda S2000
'06 Volvo V70
'14 Honda Accord LX
"Throwing food away is like stealing it from the poor and hungry" Pope Francis
Re: Fram Ultra -vs- TRD Synthetic comparison (1.8L) [Re: sdude2k2000] #4046225 03/22/16 06:31 PM
Z
ZeeOSix Offline
Z
Interesting design of a cartridge filter with metal end caps and silicone seals around the center tube. Both probably would have worked just fine, and both are close in efficiency, but the Ultra was a better value at the price paid.
Re: Fram Ultra -vs- TRD Synthetic comparison (1.8L) [Re: sdude2k2000] #4046229 03/22/16 06:37 PM
4
440Magnum Offline
4
I'd run a Champion-built filter built to better specs. That TRD is... a real trd. Champion do far better synthetic media filters for Royal Purple and Amsoil. If its available as a cartridge, that is... if not, Ultra by 10,000 miles.
'66 Dodge Polara & '69 Dodge Coronet R/T both 440/727
'08 Ram 1500 4.7/545RFE
'12 Challenger SRT8 392/6-speed
'99 XJ 4x4 4.0/AX15, '14 WK2 4x4 3.6/8HP
Re: Fram Ultra -vs- TRD Synthetic comparison (1.8L) [Re: sdude2k2000] #4046250 03/22/16 07:06 PM
N
Nate1979 Offline
N
If the current ULTRA's are actually 99.9% now I wonder if they are upgrading the other syn filters like the TRD, Amsoil, and RP?
2015 GMC Sierra 2500 6.0L
2010 Subaru Forester 2.5X
Re: Fram Ultra -vs- TRD Synthetic comparison (1.8L) [Re: sdude2k2000] #4046259 03/22/16 07:16 PM
M
MinamiKotaro Offline
M
I'll take the TRD. Not a fan of Ultras.
1967 VW Beetle: Delo 15w40/ST4386
2004 Saturn Ion: Magnatec 5w30/DW5436
2014 Polaris Ranger 570: Delo 5-40/Wix 51356
Re: Fram Ultra -vs- TRD Synthetic comparison (1.8L) [Re: sdude2k2000] #4046268 03/22/16 07:22 PM
What's funny is... based on photos I've seen online, the TRD filter looks identical to its Amsoil counterpart (EA15K01) which is also made by Champion. In some ways - it's definitely overbuilt with the Zinc end-caps and center tube... but in other ways - it looks really sloppy (the wavy and uneven pleats). I'm sure it's still completely servicable, but the thing that really took me back was rough looking seam. Is it really that hard to glue, crimp, and encapsulate like the Ultra does?
Re: Fram Ultra -vs- TRD Synthetic comparison (1.8L) [Re: MinamiKotaro] #4046271 03/22/16 07:24 PM
Care to elaborate?
Re: Fram Ultra -vs- TRD Synthetic comparison (1.8L) [Re: sdude2k2000] #4046303 03/22/16 07:57 PM
M
M
Care to elaborate?
I had an XG9018 fail.
Re: Fram Ultra -vs- TRD Synthetic comparison (1.8L) [Re: sdude2k2000] #4046315 03/22/16 08:13 PM
9
901Memphis Offline
9
I like them both but the TRD is over priced, maybe cheaper online in bulk
2012 Chevy Cruze LT 1.4T - 69k - M1HM 5w30 + Fram Ultra
2002 Buick Century 147k - Built 4T65e(Maxlife) - GTX 5w30 + Fram XG3980
Re: Fram Ultra -vs- TRD Synthetic comparison (1.8L) [Re: sdude2k2000] #4046319 03/22/16 08:18 PM
dlundblad Offline
Get whatever is cheaper. The TRD is Champ made and very high quality/ efficiency, but truthfully, I dont see the point of them besides marketing.
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 195k M1 0w40 Mahle OX149D
97 Chvy Blazer 4.3 158k M1 EP 10w30 Supertech ST3980
Re: Fram Ultra -vs- TRD Synthetic comparison (1.8L) [Re: 440Magnum] #4046324 03/22/16 08:26 PM
slacktide_bitog Offline
the TRD is virtually identical to the RP
Re: Fram Ultra -vs- TRD Synthetic comparison (1.8L) [Re: MinamiKotaro] #4046336 03/22/16 08:42 PM
N
Nate1979 Offline
N
Care to elaborate?
Did you post on here? Care to elaborate?
Re: Fram Ultra -vs- TRD Synthetic comparison (1.8L) [Re: Nate1979] #4046350 03/22/16 08:53 PM
I google'd it lol.
Failed Fram Ultra
Page 1 of 3 1 2 3
