Fury -Wilder 3?
by pbm - 02/23/20 06:41 AM
toro super recycler
by passgas55 - 02/23/20 06:05 AM
Chain style for ag tires
by puma4440 - 02/23/20 04:25 AM
2014 GMC Terrain 2.4L AWD
by Char Baby - 02/23/20 02:06 AM
Conventional VS Synthetic In The Winter Months
by BlueOvalFitter - 02/23/20 01:36 AM
Paint Splatter
by rrretiree7 - 02/23/20 12:54 AM
The Jeep Made it to 150k Miles - Storytime
by Nick1994 - 02/23/20 12:54 AM
Supertech vs Dexcool
by WA1DH - 02/22/20 11:44 PM
Spark plug gap f
by Rohan - 02/22/20 10:28 PM
Mad mike hughes.rip
by Chris142 - 02/22/20 10:15 PM
MTF drain = chocolate milk
by Texasdoc - 02/22/20 10:02 PM
New Valvoline looks promising?
by kr_bitog - 02/22/20 08:45 PM
rock like debris in generac generator 17kw
by jb5150 - 02/22/20 08:25 PM
FL820S C&P BAD GLUE JOB
by naterbomb - 02/22/20 08:21 PM
Photo Uploader Not Working
by ZeeOSix - 02/22/20 07:49 PM
Faulty clutch master cylinder 17” Honda Civic
by parshisa - 02/22/20 07:33 PM
Ford drain plugs
by buck91 - 02/22/20 07:09 PM
What's the greatest amount of miles you've heard of someone
by Speak2Mountain - 02/22/20 05:53 PM
Oil Jug - Leaking
by MasterSolenoid - 02/22/20 05:40 PM
Which one
by tiger862 - 02/22/20 05:05 PM
Markovchain, o_s, naterbomb, Jimiii, jb5150
70784 Registered Users
66 registered members (Astro_Guy, 2009Edge, Astro14, 94astro, 2013ecof150, 53' Stude, 8 invisible), 1,242 guests, and 16 spiders.
Topics301,817
Posts5,203,225
Members70,784
Chevron is now 85 octane?? #4046133 03/22/16 04:29 PM
cb4017 Offline OP
I filled my car at the local Chevron today (Northern Nevada) and was surprised to see the 87 octane labels were now 85 octane labels. Not something I expected to see with a top tier gas. Is this becoming the norm?
Cliff
USN Ret., FPD Ret.
Re: Chevron is now 85 octane?? [Re: cb4017] #4046141 03/22/16 04:39 PM
R
Reddy45 Offline
R
What elevation were you at? Higher elevation needs less octane.
Re: Chevron is now 85 octane?? [Re: cb4017] #4046142 03/22/16 04:40 PM
R
raytseng Offline
R
Well, it's different by location what "regular" "midgrade" and "premium" mean, so it's the norm, but it isn't the new norm.
The difference has to do with elevation whether regular is typically 83 or 85 or 87 or something else entirely.
Re: Chevron is now 85 octane?? [Re: cb4017] #4046147 03/22/16 04:42 PM
SrDriver Offline
85 octane is the norm at higher elevations.
Re: Chevron is now 85 octane?? [Re: cb4017] #4046154 03/22/16 04:45 PM
cb4017 Offline OP
We're at about 4,000 altitude. Around here regular gas has normally been 87 octane. Mid 89 and high octane 91. Now at this Chevron it's 85, 88 and 91. I'm going to look around and see what the other brands are doing.
I'll probably buy other brand now.
Cliff
USN Ret., FPD Ret.
Re: Chevron is now 85 octane?? [Re: cb4017] #4046170 03/22/16 05:12 PM
Chris142 Offline
Thats weird. But our premium is only 91. Some of our toys take 93+
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Chevron is now 85 octane?? [Re: cb4017] #4046188 03/22/16 05:40 PM
dave1251 Offline
Why? Less dense air means less air being squeezed in the cylinders=less power and heat. Less heat means a lower octane requirement because ignition detonation is less. So lower elevation locations require more octane and higher elevations require less.
don't use.
Re: Chevron is now 85 octane?? [Re: cb4017] #4046213 03/22/16 06:12 PM
B
BikeWhisperer Offline
B
I've spent quite a bit of time travelling through Utah which mostly is above 4000 feet above sea level. Because the air is less dense, your effective compression ratio is lower than at sea level and therefore the need for higher octane is also reduced. Almost all the stations I've used (even in St. George at 2,800 feet) are 85, 87, and 91 octane respectively. And if by chance you find yourself driving to lower elevations with 85 octane in your tank, modern computer controlled vehicles will alter the ignition timing to prevent detonation (at a loss of overall efficiency and power). I understand this is normal in Colorado as well, but I wouldn't know for sure.
With a normally aspirated engine, I wouldn't be too concerned. I ran my old 2005 Silverado all around Utah, Northern Arizona, and up through Nevada and 85 had no noticeable effects. However now both of my vehicles are forced induction which would compensate for the lower air density at altitude. In that case I would run the "midgrade" 87 in those areas just like I run regular 87 in lower elevations.
2015 F150 XLT SCrew 2.7 Eco-Boost
5w-30 Magnatec, FL2062
2018 Ford Edge SEL Eco-Boost 2.0
5w-30 Magnatec, FL-910S
Re: Chevron is now 85 octane?? [Re: cb4017] #4046316 03/22/16 08:13 PM
J
jimbrewer Offline
J
7,000 feet here. mid-grade is 87. Oddly, my Ford says to use 87 octane regular and it doesn't say anything about it being OK to use less at altitude.
Just an oversight in the manual, I imagine.
3.7L Ford
Re: Chevron is now 85 octane?? [Re: dave1251] #4046323 03/22/16 08:24 PM
Cujet Offline
Many of today's cars are turbocharged or supercharged. Altitude plays no role in turbocharged automotive engine performance. The lower octane negatively affects boosted engines. In fact, some cars require 93 octane, with good reason.
Re: Chevron is now 85 octane?? [Re: Cujet] #4046363 03/22/16 09:04 PM
B
B
In theory a forced induction engine would not lose power at altitude with the turbo/super charger compensating for the lower density. However in reality, in order to accomplish this the turbine would need to spin at a greater rpm to suck in enough air to compensate for the lower density. This will result in you needing to run higher engine rpm's to attain the power resulting in a greater lag before the power comes on. In addition, higher engine and turbine rpm's means increased engine temperatures above the designed efficiency range and increased temperatures means decreased power. Finally the CAC will not cool intake air as efficiently because the lower density air will not provide as much cooling at 6000 feet as it would at sea level.
So while they will see less power loss than a normally aspirated engine, they will still lose power.
Re: Chevron is now 85 octane?? [Re: BikeWhisperer] #4046452 03/23/16 12:09 AM
cb4017 Offline OP
The lowering of the octane is a recent change. The octane at this Chevron last time I got gas there was 87/89/91. I equate lower octane to lower quality and it irritates me to pay a top tier gas price for lower quality.
Cliff
USN Ret., FPD Ret.
Re: Chevron is now 85 octane?? [Re: Cujet] #4046492 03/23/16 02:49 AM
G
Garak Offline
G
That may be quite true, but to the gas companies really care? They sell what they've traditionally sold in a locale, or sell what they're required to sell. Only one company here has a premium above 91, simply because the rest don't "have to" and it isn't customary.
Plain, simple Garak.
Re: Chevron is now 85 octane?? [Re: cb4017] #4046552 03/23/16 05:08 AM
H
Hollow Offline
H
You can do that, but it is wrong.
Re: Chevron is now 85 octane?? [Re: Hollow] #4046569 03/23/16 05:35 AM
B
beanoil Offline
B
I don't think so.
Lets say cb has been happily paying 2.00 for 87 octane regular. There is a 20 cent spread, so 89 is 2.20, and 91 premium is 2.40. Now, his local station brings in 85, 87, and 89. If the price isn't reduced accordingly, he is paying for a lower quality fuel, top tier or not. I agree, vote with your wallet, and buy elsewhere.
