I know for my Tundra, some guys like to swap the plastic oil filter housing for the metal Venza one, p/n 15620-31060. The perforated tube has to be swapped between them because of the longer Tundra filter, but otherwise it's a straight swap. I bought one, and have yet to swap in.
Anyhow, I've been curious if the same part will swap into my 2.5L 2AR-FE. I looked a year ago and it seemed no one had tried. Today I had to do an oil change and so I compared the Venza metal one to my Camry plastic one. Call me crazy but it looks like a direct swap. The o-ring is in the same location, the tube appears to be the same length, it threads in.
I chickened out and did not install though. I also forgot to try inserting a filter, doah! However: it appears that the 2GR-FE and the 2AR-FE use the same oil filter (04152-YZZA1) so I'm not entirely sure why this can't be done.
Just an FYI, in case anyone out there wants to ditch the plastic oil filter housing.
