How do you post a pict?? I need to show you guys this
Ok,, had this truck over a mo. Im about to change my spark plugs,71k recommend change @ 30k & @ 60k top row
what happens is the rubber boot(coil over plug) glues/melt itself to the porcelain part of the plug after going through hot and cold cycles. I pulled one plug about 2 wks ago just to see how hard it would be to get it removed "without" tearing the coil boot. it was alittle tough to pull and when I got it pulled, I did noticed there was a small rubber ring that had molded itself to the plug. so I cleaned it and replaced it knowing I am going to replace them now.
Here's my question......to be able to release or break loose the seal it made.
would a warm engine making that rubber warm help break or that seal or leave it cold.. Now in other words would a cold rubber be easier to break from that seal on that plug or warm.,...or does it matter.
Well, the coils over plugs are factory coils, and I have probably also answered another question I think its better to pull these coils off with the engine warm not hot but very warm which I tried on that 1st plug about 2 wks ago. I pulled one off yesterday.... cold engine and the boot from coil came apart still was stuck down in that sleeve where the plug is once I got it out it was toast. If I can get the rest out in "ONE" piece without tearing them. Getting them out is the trick!!!! Now I thinking it best to try it warm engine I'm thinking once rubber is cold its hard to break its seal. this is an issue with this vehicle how they designed it. I don't believe at the factory they applied any di-electric grease on them just installed the coils dry.
Here is the boot Pulled off once I get it posted On a cold engine, I think I'm not even sure that would of came off with a warm engine. I Will try a very warm engine on the next 7 ..boot replacement 10.80 ea. x 8 = 86.00
