Earlier this winter I acquired an old Toro 2 cycle snow thrower. After making a few repairs the machine works really well considering it's only 3HP.
The one thing that has stumped me is... No matter how cold the units right up in a pull or two. After some use (with load) if you shut it off it will not restart until it cools off some. I put a new coil, since it needed a new pull cord, thinking the spark was weak when the unit got heat soaked. The carb has no adjustments and is a fixed jet carb.
Does anyone here have any insight or experience with this engine?
