Stewie
Thread starter
Originally Posted By: bdcardinal
Originally Posted By: JMJNet
Originally Posted By: Stewie
Mazda 3 2014, 2.0L AT
There is also a gasket in it.
I know Mazda is produced by Ford.
I am not familiar with Mazda.
The question is the Mazda transmission made by Ford?
If so, then replacing the ATF every 30K is probably help.
Use synthetic will help also.
If it is not a Ford Transmission, then you can probably treat it like a Toyota transmission as a lot of the other answer.
Unfortunately, what works for a Toyota may not be working for a Mazda.
You may also want to post in this specific car forum available in the Cyberspace.
JMHO.
This should be a SkyActiv which is a Mazda unique setup. Make sure you use the Mazda FZ fluid. It is blue, 0000-FZ-113E-01 is the part number. If you have any sort of warranty issue and the dealer sees a fluid that is not blue, we have been told to take pictures and send to Mazda corporate for guidance. We have had a couple fast lubes service the transmissions in these with universal fluid and the cars barely make it to us. All warranty coverage on the trans was denied when red tinted fluid was discovered.
Yeah they will probably charge an arm and a leg for it.
For now I will be doing drain and flush until I hit 100k
JMHO.
