quadrajet tuning for e85
Massachusetts
I've been opening up my QJs to clean and check jetting. I'm thinking of a strategy to run fat in the primary but still lean for e85 say about halfway in the middle, then complete the final tuning with the secondary metering.
The reasoning is that the carb has to be completely disassembled to get to the primary jets but the secondary metering rods are very easy to swap. They're on a hanger secured by one screw right on top. I can do it in under a minute. I'm an expert on these things.
So I'll swap secondary metering rods based on whether I'm running e10 or e85.
So hopefully we can build a thread to help each other on this. I'll be playing with it all this spring and summer and will update this thread as I learn things. I have a wideband a/f monitor and will be swapping it between the Trans Am and Corvette. Heck I might even do my 84 suburban and jet boat too. From my research you want 9:1 on alcohol rather than 14:1 and those figures are lower under acceleration.
No politics. This is about true enthusiasts using poor man's race fuel. That's it.
The ta has been running poorly since I acquired it popping thru the carb and accelerating poorly. I found 51p primary rods with 72 jets. Someone must have messed this up as it's way lean. I calculated it needs 78 jets for gas. So I ordered 79 to start then 81 and 83 jets for the e85 tune. I'm trying to collect secondary rods but they're expensive. I'm keeping an eye for used ones on eBay.
I used to have problems with the E85 drying out the accelerator pump plunger.
You gotta drive the role pin out and then take the bowl cover off to get the accelerator pump out.
I have several cellulose (nitrophyl) floats I can experiment with. The one in the vette has been submerged in e10 for 20+ years. And I've run a few tanks of e85 thru with no problems. I'm not worried about corrosion at all. I just picked up a nice 79 qj for 10 bucks so even if I destroy a carb, its no biggie.
They make the blue accelerator pump seal now that is alcohol proof. The ta already had it and I put one in the vette years ago.
Plastic float is appropiate. And you need to rake the mains out to get 30 to 40% more flow with the same depression.
I am a fan of the quadrajet. Looking forward to updates. I was running a quadrajet on my 78 until I swapped to tbi.
I don't think it'll be that much but I'll know for sure when I start tuning. The Corvette actually ran acceptably on e85 with no jetting changes. No lean backfire no bucking and half decent part throttle acceleration. I'm thinking it'll be half of that.
turtlevette,
my thesis was on flow of air and fuel in an inlet manifold...convinced my workplace supervisor that it was analogous to PF flow in a burner, which meant I could keep my cadetship...
Anyway, using gas, about 10-15% minimum of the fuel ran as a trickle along the manifold floor, at around 10% of the mean speed of the air velocity...snap the throttle open, and that fuel got washed straight into the cylinder and everything went lean until the next equilibrium state was accomplished, and it did once the slow moving fuel film got back to the end of the runner.
Problem with the 70s V-8s is that fuel/air distribution is whacked...the process that I described above, in a dual plane manifold, with variable length/hydraulic diameter/everything runners can have individual cylinders running lean misfire, while another is wildly rich...throw in a transient and stored fuel (capacitance ???) can reverse that, and the new equilibrium can change the lean/rich cylinders.
Can bypass all of that with vaporisation.
And from reading your posts re the Transam, I don't see that you are chasing 12:1 compression and 800hp (made up numbers).
Does the T/A have an intake "warmer" like a lot of the 70s cars had ?
Surely would have EGR.
I'll describe a car that I had in the '90s, a Holden HZ wagon, with 253c.i. V-8 and auto...previous owner had ditched the thermostat, so it had massive valve guide wear (1mm movement of valve head when the unworn stem was in the guide area), and a huge ridge at the top of the bore, numbers 1 and 2 being worst. The cold coolant stopped the additives in the oil forming the tribofilm, and the cast iron wore out.
Replaced the heads, manifold, and carb with a Q-Jet and later series heads, yep 800cfm on 253 inches. Holden did that in the early 80s, to rationalise parts
253 was a rubbish engine, the heads were for a 4" bore, and had overlap on the 3.625" bore.
Anyway...
After messing around with it for a bit, I had.
* Thermostat on the inlet of the water pump (sent that part to Gary Allan RIP)
* The air intake controller rigged up to vacuum with no compensator (the bimetallic strip)...vacuum, full heat, no vacuum, cold air.
* PCV (and there was a lot from the poor ring seal) was routed through a 1/2" (copper, poor choice) pipe wrapped around the exhaust manifold, and covered in kaowool (1990s asbestos)...lead into the standard central PCV port on the Q jet.
* I drilled the EGR valve with an 1/8" bit so that there was EGR at all times, maximum when at high vacuum obviously, only a little at WOT.
* ported the Vac advance to full vac advance at idle, rather than off idle Vac advance.
Results...
* ran out of idle speed adjustment
* used mixture control screws to control idle speed (lots of hot air, and the hot PCV, and the hot EGR meant that the fuel wasn't pooling, it was vapor and didn't play lean misfire until I was really lean at idle).
* had fuse wire inserted in the primary jets (same reason as above).
* IIRC (and this was fuzzy), I strengthened the springs on the secondary flaps to increase the vacuum response on the secondaries and artificially richen them up a tad at W.O.T (I spent a lot of time playing S.U. carbs before I bought a V-8).
I ended up with a machine that would do 30MPG (British), when 22MPG was standard tune, but was an absolute cow to start and run cold.
Pinging was non existant in light running or full W.O.T., but there was a fair bit of knock just at the point that you committed to overtaking.
Pontual can probably confirm how far you can lean an appropriately designed aircraft engine out in steady state (Google Lindburg and the P38).
If you can keep the T/A in vapour phase, you aren't really all that lean
Just for whoops and giggles, here's a couple of pics from my thesis...all air and fuel adjusted to stoichiometric on the test rig.
Part throttle
W.O.T
Variance in Fuel film speed versus mean air speed at multiple throttle openings.
Imagine that fuel as vapor...
I had to read thru that 4 times before I started to get it. I'd love to look thru the whole thing if its OK. You've got my email. The vette has junkyard 86 tpi aluminum heads so there is no port to the manifold for an exhaust heat crossover and making egr non functional. So I would suspect vaporization/atomization is poor. The Pontiac is stock. I'm going to put an egr block off plate on the ta as I suspect a vacuum leak is coming from there.
The QJ with the massive secondaries favors fuel flow to the rear cylinders under wot and front cylinders during normal cruise. There is a trick in Doug Roes book to make the throttle plate open more than 90 degrees to direct some flow back to the front.
Actually the biggest driveability issue on e85 with the vette is getting it to idle nicely. The later QJ has idle air tubes that prevents a rich idle mixture. There is a way to either drill out the fuel passage or restrict the idle airtube to get rich mixes. With the manual on the ta, if it idles at 1500 rpm who cares? Keeps me from stalling it.
I did a gas tank swap on the vette a few years ago and the rubber liner was absolutely perfect after 40 years of e10 fuel. The tank was starting to rust thru in spots from the outside.
Well, from my experience, and applicable literature if you dont raise the CR, you gonna get about 30 to 40 percent more consumption in a sports appli ation, because of lower BTU, leading to lower efficiency. You can recover efficiency by raising the CR, running colder plugs and retarding a little the ignition timing, sice higher ethanol content fuel have a quicker speed flame. Now if you guys had hydrated ethanol, it could be worst in consumption, but the maneuver for raising CR is even better to offset losses. The issue is around the CR. As you didnt mention raising it, the consumption could go to the ceiling at 30% to 40%, garanteed.
Originally Posted By: Shannow
turtlevette,
Yes, you can go lean, all the way to rough running, when at or below 75% power, or you'll spike the EGT ... and ruin the piston crown if you do agressive leaning at WOT...
Now the rough running issue, is directly dependant on evenly mixture distribution balanciation. The more even feeding is the admission, the leaner you can go, without missfiring a cylinder before the others. If unbalanced the manifold run of the mixture at certain rpms, the leaning (below 75% output) makes rough running, earlier.
But thats fuel conservation focused, obviously not performance focused.
I don't think it follows BTU content exactly. I feel if I go 15% richer I'll be at a place where drivability is acceptable to me. I'm not shooting for lowest drag racing et. And the corvette again, has run just fine without touching anything. I went Boston to Albany on a tank of gas and came back on a tank of e85. I believe all the negativity about mileage loss and jetting concerns are way overblown.
If I stroke the 301 from a 3" crank to a 3.75 or 4, that'll raise my compression hugely. The vette has the tiny 58 cc heads that have been shaved a few times so I'm already around 11:1
And I really dont care if I blow either of these engines up. I have a rodeck 350+ aluminum sb1 block in storage that's just itching for a home.
That's right in line with my philosophy. Lean on primary side (cruise and part throttle) and make up for it when the big bores open.
When you tune a fuel injected car on E85 you have to crank up the pump output around 30%. So if you can fatten your jets an equivalent amount then you should be at a good starting point. Stay too lean and you will lose a lot of power at cruising speed.
Most pumps don't really put out e85. more like e70
I plan to drill the idle circuit to get the vette to idle against the converter. This involves enlarging the opening in the baseplate. If that doesn't improve things, the idle pickup tube in the main body needs to be engarged too. This is more involved than a simple primary jet change but it will provide the ability to greatly richen the idle circuit, which also contributes to off idle all the way up to wot. Then when going back and forth between fuels, I'll simply adjust 2 screws and change secondary rods taking about 2 minutes.
If e85 is really about e70, I only need to increase metering area by 20% at most. I'll start by going half way at 10%.
If it turns out I need to go 20% or more, the secondary circuit will be limited, however the circuit can be drilled to open it up and the jets can be enlarged with a drill. If I have to go that far, I'll use a spare QJ.
The primary circuit has lots of adjustability as you can select jets and rods. The idle circuit will have much more range when I enlarge the feed in the baseplate and the idle restrictor tube.
I'm limited in how much I can play with the cars in the driveway because the wife keeps telling me to turn them off because they stink and its making her sick. I'm curious to see if she can smell them on e85. The nearest station is in canton. I'll run there in the cars as much as possible but I'll also buy a couple more 5 gallon jugs to run 20 gal over in the suburban at a time.
The old suburban has a 35 gallon tank. I can tap into the line at the tank and use that as a storage tank too.
Watch the math. Going from E85 to E70 a 20% reduction in Ethanol concentration. So a 30% increase for E85 needs reduced 20%, which brings you to a 6% total reduction to offset or E70. You need a total fuel increase of 24%. But the benefit here is that the octane rating is about 105, so you can increase the timing significantly.
Your station could have good quality, here is a tester that is very handy. http://www.summitracing.com/parts/qft-36...X26gaAr-R8P8HAQ
E85 burns cleaner and the scent is not a strong.
