2010 Toyota Rav 4, 4x4, Sport.
I just replaced brakes and rotors on all 4 corners with power stop pads and rotors.
Vehicle stops much better than original brakes and stops silent, no squeeks, everything feels good.
Before I did the brakes, the ebrake was not adjusted properly. It feels loose in the console, and I could get it to engage at the very end of the trail, just enough to pass inspection I guess.
So, when I removed the OEM rotors, I needed to loosen and tighten a star gear on the front of the rotor, under a rubber cover.
The manual says adjust the gear to full lock, then back it off 8 clicks to get proper brake adjustment.
So with 8 clicks, I get a ton of drag on the rotor from the emergency brake, so I had to loosen it up much more. I'm now getting a very little amount of drag, but the emergency brake is not engaging at all.
Is there any other adjustment I can make, or is it only the gear inside the rear brake rotor?
Inside the rear rotor is a little drum brake setup for the emergency brake. I cleaned it all up with brake clean, and there is plenty of shoe left on the thing, but I do not want to take it apart. I am not good with drum brakes.
Thanks,
JH
Thanks,
JH
