Today I did a drain and fill on my 2011 Sentra.....89,000 on the clock. Drained out 5.25 quarts of fluid and replaced it with Amsoil CVT. I read the system holds 7.7 quarts on Amsoil's page so not all the fluid drained out. Should I:
- drive a few hundred miles (one month) and do another drain and fill. I would have replaced 10.5 quarts (5.25x2) in a month.
- at my next OCI, which is 6K away, do a drain and fill. That OCI will likely take me 6-8 months get to.
- let it ride and do another drain and fill in 50K when I am planning on doing a drain and fill anyway. At my current daily mileage, it will take me about 4 years to get another 50K on her.
I purchased 8 quarts of Amsoil CVT so I have 2.75 quarts left. I have a vacuum pump that I can use to pull out 2 quarts and use up what I have. I could pick up another 3 quarts for the D&F easy enough. If I went with the last option, could the CVT fluid keep in my garage for 4-5 years without degradation?
Anyone running Amsoil CVT in their Sentra? If so, is there any noticeable change?
TIA for your input and opinions.
