Toyota 2TR-FE 2.7 questions
by Doublehaul. 12/12/18 12:32 AM
Anybody used Eurolub?
by FordCapriDriver. 12/12/18 12:18 AM
Micro-Green Cut Open
by David1. 12/11/18 11:45 PM
Witch way does this valve work?
by Dylan1303. 12/11/18 11:42 PM
Santa came early..
by leoblack9. 12/11/18 11:22 PM
dropped a zip tie in my prius trans
by eljefino. 12/11/18 09:54 PM
2 Cello's - Some talented fellows right here.
by StevieC. 12/11/18 09:49 PM
Something different for sure - Punjabi Celtic
by StevieC. 12/11/18 09:40 PM
Honda eu200i hiccuping @ low idle - fixed
by Jmoney7269. 12/11/18 09:34 PM
Your dealer is here - Humor
by StevieC. 12/11/18 08:46 PM
1994 Honda Civic LX Main Relay-solder
by Gito. 12/11/18 08:43 PM
Winter/Summer Fuel Economy
by RayCJ. 12/11/18 08:33 PM
0w20 oils - NOACK
by superangrypenguin. 12/11/18 08:19 PM
Liqui Moly Special Tec AA 5w20 API SN
by Johnny248. 12/11/18 08:15 PM
Buy a brand new 1966-1977 Ford Bronco
by StevieC. 12/11/18 07:50 PM
2012 Accord,QSUD 5W20,WIX 57356 filter,3K miles
by aquariuscsm. 12/11/18 07:05 PM
Check out this awsome work!
by Chris142. 12/11/18 06:47 PM
200,000 miles
by Marco620. 12/11/18 06:29 PM
tcoffin014, Schm1d, EagleC, Dinka, MechanicGuy
66654 Registered Users
45 registered members (alarmguy, benhen77, BadMonkey, 97K15004WD, 69Torino, 8 invisible), 965 guests, and 32 spiders.
Topics294,964
Posts4,924,981
Members66,654
Most Online2,553
Oct 27th, 2018
typewriter noise #3996731
02/01/16 05:24 PM
02/01/16 05:24 PM
ma
dieselguy67 Offline OP
ma
Hi guys I have a 2013 Ford F250 with a 6.7 diesel. 60,000 miles
I have used 10w30,5w40,15w40 and even 10w40 for oil choices. I have read here and on other forums about this noise after a oil changes and I also get the typewriter noise for about the first 500 miles or so. It doesn't bother me it seams to be a prevalent thing with Fords and Duramax's.
My question is what actually changes with the oil that makes it go away after some time?
Thanks Brian......
Re: typewriter noise [Re: dieselguy67] #3996842
02/01/16 07:18 PM
02/01/16 07:18 PM
Fort Worth, Texas
clinebarger Offline
clinebarger  Offline
Fort Worth, Texas
My Duramax has a typewriter tick, Mine doesn't change at all throughout a OCI, I am curious about what others will post about this.
Here is the GM TSB on the subject....Though mine is louder when the engine is cold-Opposite of what the TSB says.
Models:
2001-2015 Chevrolet Silverado
2003-2009 Chevrolet Kodiak C4500/C5500 Series
2006-2015 Chevrolet Express Vans
2001-2015 GMC Sierra
2003-2009 GMC TopKick C4500/C5500 Series
2006-2015 GMC Savana Vans
Equipped with Duramax(TM) Diesel Engine (RPOs LBZ, LB7, LGH, LLY, LML, LMM)
Some of the above vehicles may exhibit a random ticking noise that is most audible on an engine with a coolant temperature of 70C (158F) or higher and from idle to approximately 1500 RPM. The noise usually is most noticeable at the rear of the driver's side front wheel well. Customers may also comment about hearing a tick noise inside the vehicle at idle such as when sitting at a drive through window. All 6600 Duramax(TM) diesel engines have this condition; however, some are more audible than others. Engine build variation from engine to engine contributes to differences in perceived volume. All Duramax(TM) engines are manufactured to very close tolerances to meet the durability and reliability standards.
This noise is caused by the relationship of the engine cylinder block, crankshaft journals, bearing inserts and the oil film. This relationship may allow a vibration that resonates through the cylinder block and is heard as a metallic ticking noise. The noise could be described as an irregular ticking or clacking sound, like random typing on a mechanical typewriter.
This condition has been present in diesel engines produced for the last 20 or more years. The overall noise reduction in engines produced today makes this noise seem new when, in fact, it was masked by other noises in the past. Many manufacturers such as Isuzu, Hino, Mitsubishi, and Nissan report a similar condition in their diesel engines. Testing and engine teardowns with this condition reveal no condition that would affect reliability or durability of this engine.
Dealers should not attempt to compare any customer vehicles exhibiting this noise with other similar vehicles as the noise is different from vehicle to vehicle and this may lead to the incorrect conclusion that the vehicle has a condition. This noise is a normal operating characteristic of the engine. This noise has no short or long term effects on the engine. Do not attempt repairs for this noise.
2001 Chevy Camaro L92/4L80E
Re: typewriter noise [Re: dieselguy67] #3996937
02/01/16 08:53 PM
02/01/16 08:53 PM
Lakeside CA
another Todd Offline
Lakeside CA
I have a 2015 Ford PSD and it is very loud in the morning with the "typewriter noise". Then after about two blocks from my house it disappears and just goes quiet like a gas engine.
2015 Ford F250 Diesel Crew Cab FX4
2017 Ford Escape 2.0
2002 GMC Yukon
2015 Hyundai Accent
2008 Yamaha Rhino 700 FI
Re: typewriter noise [Re: dieselguy67] #3996951
02/01/16 09:16 PM
02/01/16 09:16 PM
SANTOS, BR
Pontual Offline
Pontual  Offline
SANTOS, BR
Cranck journals and bearing insets clacking ... Perfectly normal, wink
Re: typewriter noise [Re: dieselguy67] #4509767
09/07/17 07:40 AM
09/07/17 07:40 AM
Indiana
redneck47441 Offline
Indiana
From what I've read people have been able to quiet it down with different oil brands?
Re: typewriter noise [Re: another Todd] #4509772
09/07/17 07:45 AM
09/07/17 07:45 AM
Wet side WA
JohnnyJohnson Offline
Wet side WA
My 1989 Ford 7.3 Diesel ran great but it was never quiet!
2004 Corolla 126649
Out: VML 5w-30 TG4967 OCI 5007 Miles
In: EDGE EP 5W-30 Bosch 3311 122537 7-18-18
2006 Duramax 74478
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: typewriter noise [Re: dieselguy67] #4510524
09/08/17 12:25 AM
09/08/17 12:25 AM
Luling, LA
asleepz Offline
asleepz  Offline
Luling, LA
Ive run Delo, T6, and now have been running MC, they all make the typewriter noise for the first 1000 miles or so.
14F350 6.7L 86K MC15w-40/Donaldson
09Pilot 3.5L 83K PP5w-30/OEM
07Elite 80 2675mi HGMO10w-40/ScreenDoor
92Accord 2.2L 132K PP5w-30/OEM
