MANNOL ATF Multivehicle
by Ether. 03/25/19 01:17 PM
Welcome to Dusseldorf... err... Edinburgh.
by Quattro Pete. 03/25/19 01:07 PM
1NZ-FE Under Valve Cover - 280,000 Miles
by kschachn. 03/25/19 12:44 PM
Coolant Leak '06 300C
by Redright9. 03/25/19 12:40 PM
New truck
by double vanos. 03/25/19 12:26 PM
What pressure washer should I buy?
by wallyuwl. 03/25/19 11:27 AM
Natural Gas from Ohio Valley
by SubLGT. 03/25/19 11:18 AM
CVT Reliability and Durability
by raffy. 03/25/19 11:00 AM
comfortable seats
by redhat. 03/25/19 10:29 AM
walmart evinrude tcw-3 clearance score
by 1978elcamino. 03/25/19 10:15 AM
Mixing SN/d1G1 with SN+/d1G2?
by doyall. 03/25/19 10:14 AM
Best 2nd Phone Number App ?
by LoneRanger. 03/25/19 09:56 AM
Crud! Wix jacking up prices again! :(
by SubieRubyRoo. 03/25/19 09:53 AM
Interior "quick detailer"
by Redright9. 03/25/19 08:21 AM
Seafoam For Last 100 Miles Before Oil Change ?
by ChrisD46. 03/25/19 07:56 AM
WIX 57151XP factory filled with synthetic oil
by Donald. 03/25/19 06:58 AM
BMW Buying Guide: Every Model, Explained
by wemay. 03/25/19 05:43 AM
Double Din Android Auto Advice
by JeffKeryk. 03/24/19 11:25 PM
VW mk5 a/c intermittently works
by ram_man. 03/24/19 11:01 PM
sonusfaber, Rollo, Drifted, Jcar516, gregjr7
67614 Registered Users
130 registered members (2012AccentSE, 97K15004WD, 4WD, 64bawagon, 2009Edge, 240_Ed, 11 invisible), 2,197 guests, and 72 spiders.
Topics286,400
Posts4,907,633
Members67,614
Most Online2,967
Mar 10th, 2019
Tie-rod ball joint grease? #3989096
01/24/16 10:20 PM
01/24/16 10:20 PM
USA
garlicbreadman Offline OP
USA
Hi,
The rubber boot for the tie-rod on my 01 acura integra tore. I am going to replace the boot next weekend and need some grease suggestions.
i found these two, what do you think?
http://www.amazon.com/Super-Lube-21030-S...rds=moly+grease
http://www.amazon.com/Valvoline-VV985-Sy...rds=moly+grease
At home i have:
mobil 1 synthetic grease (i used this red goop on my upper control arm ball joint and the rubber boot is all moist)
napa sil-glyde
3m silicone paste
Please let me know what is appropriate in my application. Thanks
Re: Tie-rod ball joint grease? [Re: garlicbreadman] #3989144
01/24/16 11:16 PM
01/24/16 11:16 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
Mobil1
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Tie-rod ball joint grease? [Re: garlicbreadman] #3989160
01/24/16 11:40 PM
01/24/16 11:40 PM
South Eastern, CT
AMC Offline
AMC  Offline
South Eastern, CT
I like Valvoline synpower and I recommend you stick with lithium complex based greases for compatibility reasons. Mystik JT-6 hi temp, lucas marine, and Omni Green Grease are good choices as well.
18 Honda CR-V - Mobil-1 AFE 0w-20
17 Ram 1500 SLT - Napa Synthetic 5w-20
14 Yamaha Super Tenere - Mobil Delvac 15w-40
Re: Tie-rod ball joint grease? [Re: garlicbreadman] #3989161
01/24/16 11:44 PM
01/24/16 11:44 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
Sta-Lube SL3110
Re: Tie-rod ball joint grease? [Re: garlicbreadman] #3989195
01/25/16 01:11 AM
01/25/16 01:11 AM
KingCake Offline
KingCake  Offline
Ford Lincoln Mercury Grease. Either from Ford or Valvoline at Autozone.
It's the only grease I know of besides some GM stuff that has polyethylene particles in it to dampen vibration and noise. It also has moly.
BUT--if you got Mobil grease at home already just use that I doubt you'll notice the diff.
Re: Tie-rod ball joint grease? [Re: KingCake] #3989210
01/25/16 02:11 AM
01/25/16 02:11 AM
USA
USA
I think i will pick up some of the stuff you mentioned. I assume this type of grease is rubber safe?
http://www.valvoline.com/our-products/grease-gear-oil/moly-fortified-multi-purpose-grease
I dont like the m1 stuff. It seems to run....i used it in a balljoint and the boot is covered in grease.
Re: Tie-rod ball joint grease? [Re: garlicbreadman] #3989213
01/25/16 02:32 AM
01/25/16 02:32 AM
KingCake Offline
KingCake  Offline
Yes the red M1 does separate real bad. Why I quit using it.
The Ford grease is what ford uses in all their ball joints and ties rods. It won't hurt the boot. You can get it in a tube also.
O'reilly and Autozone both carry it.
Re: Tie-rod ball joint grease? [Re: garlicbreadman] #3989337
01/25/16 08:21 AM
01/25/16 08:21 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
The best grease for tie rods and ball joints i have used over the years bar none is the Schaeffer 238 #2. From what you have the Mobil 1 would be my second choice.
http://stores.buyschaefferoil.com/products/schaeffer-238-grease-moly-ultra-supreme-1-2-3-1-tube.html
Re: Tie-rod ball joint grease? [Re: Trav] #3992234
01/27/16 10:06 PM
01/27/16 10:06 PM
lllinois
salesrep Offline
salesrep  Offline
lllinois
thumbsup
High quality Specialized Lubricants pay for themselves!
Re: Tie-rod ball joint grease? [Re: garlicbreadman] #3992322
01/28/16 12:42 AM
01/28/16 12:42 AM
West Michigan
buck91 Offline
buck91  Offline
West Michigan
As another posted mentioned, I really like the Valvoline Synpower grease. It seems to stay put very well and with the spec's and the moly content it lubricates very well.
Additionally its extremely versitile. It offers an extended temp range to cover cold winters and hot disc brakes, moly to help in high loads like ball joints... but not so much moly to cause problems in bearings (I don't have it writen anywhere but IIRC valvoline claims 1%). Plus, I've had the same tube in my gun for about two years with nary a drip or leakage. Its kept in the garage 80% of the year but I store inside during winter so I can use it if needed without waiting for the grease to warm up to an easily pumpable temp.
edit: I feel compelled to add... also based on my own understanding, the key ingredient to tube rod lube is refreshing the grease as needed. Basically almost any qualified grease will work perfectly as long as you regrease it as needed.
2011 F150 4x4 5.0L
1996 Mustang GT 5spd/ragtop
Re: Tie-rod ball joint grease? [Re: garlicbreadman] #3992329
01/28/16 01:05 AM
01/28/16 01:05 AM
USA
USA
Thanks all.
Got me a tub of the Synpower grease. Can't wait. Ebay has the best prices as well...free ship and no tax laugh
http://www.ebay.com/itm/Grease-Ext-Pres-and-High-Temp-1lb-Gray-VV986-/111759138466?hash=item1a055d1ea2:g:ozMAAOSwTapV5Hdt&item=111759138466&vxp=mtr
Re: Tie-rod ball joint grease? [Re: garlicbreadman] #4014328
02/18/16 12:13 PM
02/18/16 12:13 PM
Sweden / Stockholm
magnus308 Offline
magnus308  Offline
Sweden / Stockholm
The red Mobil 1 grease is the worst garbage i ever used, Its completely useless.
The last application i tried to use it on before i threw it away was on door hinges but not even on that simple application it worked well.
It separates instantly..
Volvo 940 LPT 1998 Classic
Re: Tie-rod ball joint grease? [Re: magnus308] #4025406
02/29/16 03:54 PM
02/29/16 03:54 PM
USA
USA
I agree, i dont like it at all
I installed the boot and regreased with valvoline synpower. Feels good, feels like before lol
Thanks for those who suggested the valvoline product. So far happy with it and will use it for many things.
Re: Tie-rod ball joint grease? [Re: magnus308] #4025550
02/29/16 06:49 PM
02/29/16 06:49 PM
Illinois
tig1 Offline
tig1  Offline
Illinois
I have used M1 grease for many years(at least 20) and have found it to lubricate very well. My old 91 Ford Ranger was greased with M1 and in 354K (miles) never had to replace a greased part. The same for the front wheel bearings that was greased with M1. Actually, the better grease does separate a little. Here is an article that explains why grease must separate(bleeding) to lubricate properly.
http://www.machinerylubrication.com/Read/28761/storing-grease-to-avoid-bleed-separation-
2007 Ford Fusion 239,000 miles
M1 0-20 EP
2017 Ford Fusion 67K
M1 0-20 EP
M1 ATF and Valvoline LV
M1 10-30 in all OPE
MC filters
Re: Tie-rod ball joint grease? [Re: garlicbreadman] #4044221
03/20/16 04:47 PM
03/20/16 04:47 PM
Va.
Piston_slap Offline
Piston_slap  Offline
Va.
I bought my first tub of Valvoline Ford/Mercury back in the 1970's as this grease exceeded all manufacture's standards at the time. It's wonderful grease that you can depend on.
1994 Ford Econoline w/302 & 4R70W
Valvoline 10W-40, Motorcraft FL1
Isotope U235
