Originally Posted By: Shannow
Originally Posted By: Hujan
Thanks for that link. That video is pretty awesome. It was neat tot see the side-by-side of the different oil weights try to pour in that super cold temperature. It almost looked like you could break a piece off of the last one. I do see the attraction of a 0w from that video, but I get your larger point.
I have some followup questions if I may:
1) Will all oils of the same winter weight grade flow pretty much the same as each other at cold temps? Or does can it adjust up or down based on other factors?
If you are 10 or so degrees off the cold test temperature for any "w" grade, they will get to the pick-up (and thus be pumpable), and fill the galleries at about the same rate.
People post pics of ball bearings falling in cylinders of oil, oil trickling down a sheet of steel, oil falling through orifices etc. and and claim higher flow for thinner oils...but your engine has a positive displacement pump which will shift the same volume of oil with every revolution.
When first started, any pumpable oil will get oil to the remote ends of the engine at pretty much the same time.
The thicker oil will cause the pump relief to be open to a greater extent, and less total flow to a pressurised engine, but the nature of bearings is that they only need the supply, and will draw off what they need...you aren't "pumping" oil through the bearings.
2) Does the second number have any influence on the oil's cold flow? In other words would you expect a 15w40 to flow the same, better, or worse at cold temps than a 10w60?
Again, back to the definition of the "W" part.
It's the ability of the oil to make it to the oil pump (the MRV), and the ability for the engine to crank over (the CCS), not strictly "flowability" per se.
As per 1, the concept of "flow" like a waterfall to your bearings isn't what's happening in your engine.
If you are at -30 or 40F, then the 0Ws, or 5Ws have an advantage over a 10W.
At freezing temperatures, you will have no difference between the "flow" to the bearings on startup between 15W40 and 10W60.
3) Does comparing the KV40 of two oils give us a sense of, say, their viscosities at 20 C, 10 C, or 0 C? It seems odd to me that one oil would be less viscous than another at 40 C but more viscous than the other at 0 C. Is that accurate?
Depends on the viscosity index, and the KV100 (Viscosity Index is calculated off the KV40 and KV100)...use the calculator that bluesubie linked to for a graphical representation...really only accurate down to freezing.
There's also a viscosity calculator ap
here which I've got on my phone and find really handy.
Grab the data sheets for M1 0W30 and 5W30 and plug them in...the 0W is thicker (slightly) at 0C than the 5W...both would be expected to behave identically above freezing (viscosity alone, there are other factors).
Just to try to close out my point about pumpability, here's a chart from a paper. The RAOT is rocker arm oiling time, the time it took from start to get oil flowing from the remotest rocker, and the FOPT is the time to full oil pressure.
It's specific to this engine, but the results hold true for the concept that I am trying to get across.
The SAE 30 (straight grade, no "W" rating) had oil to the rockers at 3 seconds and full oil pressure at 6 seconds at 30F...at 20F, it took much longer to get to the remote rockers, and at 10F, much longer for both...clearly, the SAE30 was fine above freezing, but started to suffer below that.
The 10W30 was about as good/poor at -9F, as the SAE30 was at 10F.
The 5W20 was about as good at 9F and the SAE30 at 30F, and as good at -11F as the SAE 30 at 20F.
The missing link in the chart is that if all of the oils were shown at 30F, they would replicate the 3 and 6 seconds, as the flow in the case of a pumpable oil is dictated by the volume of the oil pump.
So again, in a place that doesn't see freezing, you don't have anything to gain by chasing "W" rating, nor KV40.
Not for a second suggesting that you would run an SAE40 in it. But in a non freezing climate, the viscosity would work (KV40 145, KV100 14.9, HTHS 4.3+)...if you drove up to the Donner Pass, it wouldn't.
So pick a decent oil with an HTHS in the range that you want, and get a "W" rating appropriate for your conditions, and you'll be fine.
Great stuff and thanks for your patience explaining these concepts so well. The charts, graphs, and analogies really help. A lot of this stuff is counter-intuitive (e.g., how positive displacement pumps change the game).
I'm curious your thoughts on the original question in this thread, specifically whether there's any advantage or disadvantage to an ester-based oil like Motul, all else being equal (weight, additive pack, etc.). I suspect you'll say it's irrelevant but thought I'd ask. I raise it because I really like what I see from Motul 300v 15w-50 and even Redline 5w-15.
