Originally Posted By: Nate1979
Do you still have the previous tires? No vibe until putting the new ones on? Can you swap to the old ones just to confirm? Wouldn't be the first time a coincidence happened.
Correct. No vibe with the Original Tires. I had the Initial Tire shop break the bead so they could remove the Tire Pressure Monitors so I can't re install them at the moment. Being a BITOGER, I'm always very aware of how my vehicles are running/driving. Definitely no vibe before.
