I have a 99 Nissan Almera which occasionally grinds / doesn't engage when I try and put it into fifth gear.
I was talking to someone about changing the gear oil since I'm going to replace the cv boots. The Hayens manual says my tranny takes Hypoid gear oil, viscosity SAE 80W to API GL4. This person recommended that I use Valvoline 75w-90 Limited Slip to help with the problem I'm having shifting into fifth gear.
According to the http://content.valvoline.com/pdf/synpower_gear.pdf product information sheet on Valvolines website it meets GL4,GL5 and MT1 ( whatever those are ).
What is this "limited slip" thing they are talking about and might it help my problem, as opposed to refilling with some cheaper oil like regular 75w-90 or 80w?
