Originally Posted By: NHGUY
You get unlock under deceleration to aid in braking.The computer sees you off the gas pedal,it assumes you may want to slow down or (soon) stop.It cannot predict if you ARE going to stop or brake so it guesses.Imagine if it didn't unlock...all road RPMs would be fed to the engine,not assisting in slowing.
If the torque converter didn't unlock, the transmission would have to turn the engine at a higher speed when coasting, which would aid in braking.
