Howard's cams now requires a straight 20 or 30 weight oil for cam break-in. If flat tappet, the procedure has to include ZDDP additive. They specifically say not to use a multi-grade oil ...
I have run a lot of Howard's cams. They carry a 5 year warranty if used with matching lifters. So following their procedure is no joke for engine builders.
They say a Pennsylvania based oil is preferred...
I'm think Brad Penn, but gimmie some other options...
