Originally Posted By: KitaCam
Originally Posted By: CapriRacer
A couple of thoughts:
First, tires of the same size and type can vary greatly. It is hard to make blanket statements because there is some overlap.
Yes, summer tires TEND to be better handling / harsher riding than all season tires, but there are some exceptions.
The same is true of treadwear, traction, and fuel economy.
So careful selection is called for.
Florida is known for its abrasive roads. And the abrasion levels are worse in South Florida than in northern FL.
Florida is also known as an area with more vibration complaints. That's because Florida roads don't experience the freezing and thawing that causes northern roads to heave and become uneven - which disguises out of round and out of balance tires and wheels.
As a south Flordian I can totally confirm this^^^^^....Rubber compound and tread design are more important than the "summer" or A/S designation.
There is much more to be concerned with construction and design in terms of PURPOSE....here in FLA I chose RAIN dispersion as my highest criterion...2nd was a quiet ride...both a function of tread design....Hankook Ventus tires I had a couple years ago (now the Hankook Ventus v12 evo2 k120) were excellent in dry and wet conditions but were LOOOUUUUD...a cheap imitation/version (Sumic/Doral/Aspen) A/S tire was okay in Florida temps but dangerous in 30° Chicago rain..despite being designated A/S, the tire hardened up at freezing temps and had little grip in freezing rain...scary....
Dry road gripping soft tires (a function of rubber compound chemistry) wear more quickly more than harder compounds build for tread-life, but because NO tire lasts the expected mileage here due to the shell impregnated roadways in Fla, I prefer the softies...
Finally, softer tires STAY softer in colder weather for less slip'nsliding on rain soaked roads when the temps get in the low 30°s...some summer tires (like the Ventus, a 3-season tire based on its tread design....though Hankook claims it's A/S) fit these criteria, but many more A/S tires will as they're made for colder temps....
My current tire has performed well here in Florida...Cooper CS5 ultra touring.
Best tire in rain that I ever had was Michelin Pilot Super Sport.
Are there better A/S tires when it comes to resistance to hydroplaning? Probably yeah, but all thing considered, advantage is negligible.
Are there A/S/ tire better in handling or braking in rain? NO! I had various A/S, tires and yet to find one that brakes on par with performance summer tires in rain, especially these Michelin PSS. I had Bridegestone Potenza, Continental Contisport, Michelin PSS, Good Year Eagle F1, and all had better wet capabilities then any AS tire I had.
