Credit Increase- CC's
by Zee09. 02/21/19 08:24 AM
High iron and silicon
by landyman. 02/21/19 08:21 AM
13 Titan Vibration in 4th gear.
by Anthony. 02/21/19 07:36 AM
DEF Consumption
by wings&wheels. 02/21/19 07:06 AM
Which Natural Gas Water Heater to Get?
by LoneRanger. 02/21/19 06:58 AM
2016 Crosstrek Windshield Washer reservoir
by Donald. 02/21/19 06:43 AM
Whistling wipers!
by mclasser. 02/21/19 06:39 AM
Going by HTHS
by JLTD. 02/21/19 02:59 AM
Quick Struts vs Replacing the struts by themselves
by das_peikko. 02/20/19 11:50 PM
Walmart Oil clearance # 2
by GMguy84. 02/20/19 11:14 PM
ST Syn in a TGDI?
by BTLew81. 02/20/19 09:52 PM
The Virus That Kills Drug-Resistant Superbugs
by StevieC. 02/20/19 09:50 PM
Opinion Of Dodge Nitro
by Warstud. 02/20/19 09:26 PM
Cheap first car
by LeakySeals. 02/20/19 09:08 PM
Grand Caravan break in
by pda1122. 02/20/19 09:07 PM
Million mile Lexus
by Skippy722. 02/20/19 08:57 PM
AtomicNumber53, waynea, txan, pman9003, alienyouth33
67298 Registered Users
95 registered members (Al, alienyouth33, 2004tdigls, 1foxracing, Alfred_B, 13 invisible), 1,521 guests, and 51 spiders.
Topics284,600
Posts4,873,164
Members67,298
Most Online2,548
Feb 16th, 2019
Fram Ultra XG6607 cut open - 14k miles #3941671
12/09/15 01:54 PM
12/09/15 01:54 PM
Portland, OR
Nate1979 Offline OP
Nate1979  Offline OP
Portland, OR
Here is a Fram Ultra XG6607 cut open off my 2010 Subaru Forester. It was run for 2 OCI, total ~14k miles and 14 months. No issues, looked great. Silicon anti drain back valve was still very pliable.
2015 GMC Sierra 2500 6.0L
2010 Subaru Forester 2.5X
Re: Fram Ultra XG6607 cut open - 14k miles [Re: Nate1979] #3941718
12/09/15 02:38 PM
12/09/15 02:38 PM
S California
OneEyeJack Offline
OneEyeJack  Offline
S California
It does look like an oil filter, only smaller. (lol)
Looks good. Doing every other oil change with a modern engine and synthetic oil looks like a good idea.
Re: Fram Ultra XG6607 cut open - 14k miles [Re: Nate1979] #3941801
12/09/15 03:40 PM
12/09/15 03:40 PM
Regina, Saskatchewan
sir1900 Offline
sir1900  Offline
Thanks for sharing. Looks great.
2015 Infiniti Q50
VAS 5W-30 + FRAM PH6607
2015 Nissan Murano
Mobil1 AFE 0W-20 + FRAM XG6607
Re: Fram Ultra XG6607 cut open - 14k miles [Re: Nate1979] #3941841
12/09/15 04:17 PM
12/09/15 04:17 PM
Phoenix, Arizona - USA
SirTanon Offline
SirTanon  Offline
Wow.. that IS a tiny filter. Same one used on my 2014 Altima. Supposedly, the 7317 is the 'oversize equivalent' to this filter. Can't say from personal experience, though.
2010 Ford Fusion SE - 2.5 liter/6F35 Trans - 270,000mi
2014 Nissan Altima SL - 2.5 liter/CVT - 62,000mi
Re: Fram Ultra XG6607 cut open - 14k miles [Re: Nate1979] #3941917
12/09/15 05:51 PM
12/09/15 05:51 PM
USA
slacktide_bitog Offline
USA
What a tiny filter! Even lego engines and lawn mowers use a bigger filter than that! Get a 7317 if it fits smile
Re: Fram Ultra XG6607 cut open - 14k miles [Re: Nate1979] #3941927
12/09/15 06:01 PM
12/09/15 06:01 PM
FL, USA
gregk24 Offline
gregk24  Offline
FL, USA
Just keep using the correct filter, its obviously doing the job.
2012 Honda Accord EX-L K24z3
56,xxx miles
PPPP 0w20 / Fram Ultra
2014 VW Jetta SE 1.8T ea888
44,xxx miles
Castrol OEM dealer fill / OEM filter
Re: Fram Ultra XG6607 cut open - 14k miles [Re: SirTanon] #3942108
12/09/15 08:26 PM
12/09/15 08:26 PM
Virginia
bbhero Offline
bbhero  Offline
Virginia
Yep. I use the 7317 on my Altima 3.5 coupe. The 6607 looks like it ought to be on a Briggs and Stratton. The generation of VQ35 was specd for the 7317. This 6607 does look good though. Thanks for the work on this dissection smile
Nissan Altima 3.5 Coupe
Mobil Super 5w30 Wix 57356
"Treat your family like your friends and treat your friends like your family."
Re: Fram Ultra XG6607 cut open - 14k miles [Re: Nate1979] #3942170
12/09/15 09:38 PM
12/09/15 09:38 PM
Portland, OR
Nate1979 Offline OP
Nate1979  Offline OP
Portland, OR
I know its a small filter but I generally prefer to run the specified filter.
Re: Fram Ultra XG6607 cut open - 14k miles [Re: Nate1979] #3942196
12/09/15 10:08 PM
12/09/15 10:08 PM
Virginia
bbhero Offline
bbhero  Offline
Virginia
The psi rating on the 7317 is exactly the same with both, thread size, gasket size obviously too. Is there more media?? More than likely but they both need to be cut down and measured to see what is really the case. At minimum I like having the upsize one because its easier to get a handle on. If that's all I truly get out of it I'm fine with that.
Re: Fram Ultra XG6607 cut open - 14k miles [Re: Nate1979] #3942197
12/09/15 10:09 PM
12/09/15 10:09 PM
New Jersey
crazyoildude Offline
New Jersey
The ultra for the most part seems like a great filter.
Check To See That The Oil Jugs You Buy Have The Exact Amount Of Oil In Them And Have An Inner Seal Under The Cap. I Use Mobil 1 And Fram Ultra Filters
Re: Fram Ultra XG6607 cut open - 14k miles [Re: bbhero] #3942216
12/09/15 10:48 PM
12/09/15 10:48 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
The 7317 will definitely have more media than the 6607.
XG6607 = 2.63" long
XG7317 = 3.47" long
Re: Fram Ultra XG6607 cut open - 14k miles [Re: Nate1979] #3942504
12/10/15 09:49 AM
12/10/15 09:49 AM
Indiana
dlundblad Offline
dlundblad  Offline
Indiana
Also as Zee0Six pointed out a while back, the 9688 and 7317 are almost the same size. (I always assumed they were a bit larger.)
The 3 have the same gasket/ bypass, but while the 9688 is larger in diameter, it is slightly shorter than the 7317.
I use the 9688 size in the garden tractor though and it just fits. I worry the 7317's additional length would rub on the hood.
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 186k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 153k Synpower 5w30 Supertech ST3980 (Ecore)
Moderated by  ekpolk
