(3) 5-quart + Fixd ODB-II reader for $40.50+tax
by wkcars - 04/03/20 09:57 PM
Tesla Crushing It
by JeffKeryk - 04/03/20 08:42 PM
Pacific Valley in Big Sur with the E46
by SLO_Town - 04/03/20 08:33 PM
I drove a Delta pilot to the airport today
by 14Accent - 04/03/20 07:41 PM
ALUMINUM BLACK™ metal finish touch-up pen
by vavavroom - 04/03/20 07:28 PM
Strut leak
by ford46guy - 04/03/20 06:30 PM
Orifice tube backwards, now can’t reach it
by gallydif - 04/03/20 06:14 PM
Bone creeper?
by JHZR2 - 04/03/20 05:58 PM
Wrangler TJ Engine Oil
by TJim - 04/03/20 04:53 PM
Virgin XG3600 cut open
by bullwinkle - 04/03/20 04:30 PM
Windows Update and Shutdown update confusion
by simple_gifts - 04/03/20 04:29 PM
Mildew Smell in AC System
by painfx - 04/03/20 04:17 PM
M1-113A CUT OPEN
by 53' Stude - 04/03/20 03:56 PM
MC FL500S 7,000 miles CUT OPEN
by 53' Stude - 04/03/20 03:43 PM
USS Theodore Roosevelt
by BMWTurboDzl - 04/03/20 03:42 PM
2020 Subaru Forester Base
by wagsrk08 - 04/03/20 03:41 PM
New Rislone Hy-per Fuel Product?
by Jackson_Slugger - 04/03/20 03:38 PM
Rislone New Gas Hy-per Cleaner Rebate
by Jackson_Slugger - 04/03/20 03:33 PM
2003 GM 6.0 LQ4 Oil Pan/Rear Main Leak, which oil
by apollo18 - 04/03/20 03:15 PM
FRAM Extra Guard PH16 CUT OPEN
by 53' Stude - 04/03/20 03:11 PM
Peacock, Agauth12, PatGN, Fjordman95, TJim
71086 Registered Users
105 registered members (ammolab, Alaskanmont, 4WD, antonmnster, 01rangerxl, 53' Stude, 13 invisible), 1,914 guests, and 18 spiders.
Topics303,551
Posts5,237,307
Members71,086
Page 1 of 3 1 2 3
Brand new silverado metal shavings #3939227 12/06/15 11:53 PM
R
Realtech214 Offline OP
R
checked the oil on my 2015 silverado tonight. Truck now has 1300 miles on it, Not yet done first oil change.
The dipstick when pulled out has some very small shavings on the end of it, when wiped off you cant even really see on the rag. Just enough little fuz of metal on the end when you pull the stick out. I guess this is normal on an brand new engine?
Maybe I should get the oil changed soon at like 2K miles! Thanks
2015 Silverado Crew Cab 5.3 LT 120,xxx miles
2001 Suburban LT 145,xxx miles
Re: Brand new silverado metal shavings [Re: Realtech214] #3939233 12/07/15 12:02 AM
Dyusik Offline
Break in, but I would be uneasy knowing there is wear material in the oil large enough to be see with the naked eye. Others would pull the wasteful card, or OE recommends, but not I. Throw a magnet on your drain plug to see how much sticks. And be sure to share the oil filter cutting that I want you to do. smile
95 Cherokee 190K DELO XLE 10W30, XG8
04 YZF-R1 20K Frankenbrew 20w50ish, XG7317
14 RX450h 50k M1 AFE 0w20, WIX 57047
18 RAM 3500 10k Delvac 15w40, DBL7349
96 Cherokee
Re: Brand new silverado metal shavings [Re: Realtech214] #3939234 12/07/15 12:09 AM
G
gabriel9766 Offline
G
did you follow the break in procedure in the Manuel? my 2015 has 3,900 and the oil is already very dark. i plan on changing it around 4,500-5,000 miles depending on how soon it gets cold. the break in procedure for my malibu was to drive the vehicle at different speeds for the first 500 miles and not to drive at a constant speed for the first 500 miles.
2018 Mazda6 Touring 2.5L MC 0W20 7,434 (CPO)
2007 Escape XLT 3.0L 6Q MC 5W30 117K
2010 Fusion SE 2.5L MC 0w20 117K
2008 Escape XLT 2.3L MC 5w30 198K
2007 Fusion SE 2.3L- 186K MC 5W30
Re: Brand new silverado metal shavings [Re: Realtech214] #3939237 12/07/15 12:12 AM
stower17 Offline
Brand new you say? Put the dipstick back in and drive it and then do first change according to the OLM or earlier if you do so choose.
Re: Brand new silverado metal shavings [Re: Realtech214] #3939239 12/07/15 12:17 AM
stower17 Offline
Changing the oil now isnt going to stop the metal shavings from reappearing, it'll stop when the engine breaks in. The filter will capture the metal. Any oil in the sump hasnt been filtered yet... i bet that oil is plenty good once it goes thru the filter i bet it looks like new. Magic!
Re: Brand new silverado metal shavings [Re: Realtech214] #3939241 12/07/15 12:21 AM
MrQuackers Offline
Yep the oil is pumped to the filter where the shavings are trapped and pure oil goes through the bearings.
Master the 1000 yard stare
coffeeMobil 1 USA
Re: Brand new silverado metal shavings [Re: Realtech214] #3939242 12/07/15 12:22 AM
2015_PSD Offline
Many here will disagree or say it is a "feel good" exercise, but I always dump the factory fill in my new vehicles between 1000 and 1500 miles to get the break-in garbage out. I typically follow that with one more 3000 to 4000 miles later and then begin normal OCIs. If it were mine, I would change it and install a Gold Plug drain plug at the same time. Will this make any difference in engine longevity? There is no proof either way, but it means something to me.
2019 o)|||||(o Rubicon Wrangler Unlimited 3.6L V6 [Castrol Edge + Hastings]
2018 Mercedes Benz C300 2.0L Turbo [Pennzoil Platinum + Mann filter]
Re: Brand new silverado metal shavings [Re: Realtech214] #3939265 12/07/15 01:57 AM
dishdude Online Content
Online Content
A UOA would be interesting, I'm wondering if this isn't air bubbles or something like a preassembly lube.
2018 Challenger SRT 392 PUP 0w-40 Wix 57899XP
2018 GTI M1 Euro 0w-40 Wix WL10024
2019 Tiguan Castrol Edge Pro 0w-20
Re: Brand new silverado metal shavings [Re: Realtech214] #3939266 12/07/15 02:00 AM
G
Gasbuggy Offline
G
I've seen air bubbles before and thought "metal flake?" Then nothing shows up on the cloth.
Cadillac CTS-V 6.2L 10w30PP
Volvo P1800 Euro L
76 Mercedes 300D Rotella T4
Series III Land Rover VWB
02 Yukon 10w30 PP
01 P71 M1 EP-HM 0W20
95 Accord - 386k. Mobil 2 RIP
Re: Brand new silverado metal shavings [Re: Realtech214] #3939280 12/07/15 03:17 AM
SuperDave456 Offline
Wipe the dipstick with a paper towel, then get a magnet and see if the paper will stick to the magnet.
If so you know your drain pan has shavings in it.
If not, their bubbles.
Re: Brand new silverado metal shavings [Re: Realtech214] #3939455 12/07/15 10:12 AM
B
Branson304 Offline
B
It's just from engine break in. As others have said, the filter will catch the metal shavings so do not worry. Go at least 3,000 miles on the factory fill before you change it, but I always go 4,500-5,000. This is nothing to worry about!
Re: Brand new silverado metal shavings [Re: Realtech214] #3939491 12/07/15 10:36 AM
cb4017 Offline
I've also seen this on a few different vehicles over the years. Consider this possibility. The dipstick is stiff, has sharp edges and is shoved through a curved tube. Could the dipstick be picking up the tiny shavings as it's being inserted into the engine?
Cliff
USN Ret., FPD Ret.
Re: Brand new silverado metal shavings [Re: Realtech214] #3939506 12/07/15 10:53 AM
cptbarkey Offline
It is neat to look at the shiny sparkles isnt it?
Re: Brand new silverado metal shavings [Re: Realtech214] #3939632 12/07/15 01:03 PM
SilverC6 Offline
Change the oil and filter immediately.
Could be contaminated by the oil filter thread cuttings.
Just like the Corvette Z06 that lunched an engine while being tested by Motor Trend.
Better safe than sorry.
'10 & '11 Camry 0W-20 PP
'11 Landcruiser 5W30 PP
'13 BMW 550IX Castrol 0W40
'08 BMW Z4M Coupe TWS 10W60
'13 BMW M6 BMW 5W30
Re: Brand new silverado metal shavings [Re: Realtech214] #3939760 12/07/15 03:00 PM
Z
ZeeOSix Offline
Z
Always good to cut open the factory oil filter to get an idea if the break-in went well. Don't want to see a bunch of crud or metal shavings in the filter, even on a new break-in. A little would be normal, but if it seems like a lot something might be going on.
Page 1 of 3 1 2 3
