I've ran JP8 + 15w40 in Mraps and hmmwvs and lmtvs many times.
When an engine is built for diesel and you use jet fuel in it, things tend to leak due to lack o lube in fuel
No issues. Actually the MAXXPRO Started heck of a lot better in Afghan Mountains with the oil in the fuel when it got to sub freezing negative degrees and snow.
I always did 1 qt to 20L of fuel. New or used oil. Safety Kleen 15w40 mil spec oil
