After owning many crown vic P71 police cars, some burn oil and some don't. Its more an age thing. Some of the 175k + units that are newer don't burn a drop, others with less than 100k do. What I do know is you you see blowby, chances are the oil rings are worn. If you do not see any, it is most likely the valve stem seals. Even after 1996, they can still wear, and there is a lot of oil flow up there.
