when to change atx fluid on low mileage cars?
Can
when to change automatic transmission fluid on vehicles that don't get no were near the mileage change interval???
Every 3 years a drain and fill would be nice. Brake fluid as well while you're at it. Turkey baster method for the power steering fluid.
Wear metals in a transmission are highest during the first year or so - after that wear metals taper off a lot.
A couple of early ATF drain and fills are prudent to get the extra debris out from the break-in process.
After that, a normal maintenance routine is in order.
Search MolaKule's posts for his research. As mentioned, wear is highest when the tranny is new and early changes are prudent.
Alright I ll try and find his threads.. the car is 2009 and only has 12000 miles
Change it now if it's a concern for you. It could potentially be another 10yrs before that vehicle has ~36K miles on it.
I think most would say change it around 3yrs/36K miles, which ever comes first. Following that would be doing more than almost every vehicle on the road has done. Does doing this help? I can't see how it would hurt. I know I've done it.
