I own a 08 Full sized range rover with the Jaguar 4.2 L supercharged engine. 410HP 425tq, It runs 13 lbs boost and holds 8 quarts of oil. I typically run Mobil 1 EP in all my cars due to it being cheap at Walmart and easy to get. I have been running M1 5w/30 EP and changing it at 10k miles. The factory OCI is 7k with Dino juice. This truck get some pretty heavy use. It weights almost 6,000 lbs and i just pulled a 16 foot enclosed trailer loaded with around 6k lbs 4800 miles 10-12 hours at a time. Although i do not typically tow a trailer that much maybe 1k miles a year. I do drive 30k+ miles a year so the longer the OCI the better as i don't have to change it as often. The manual says you can use anything from 0w-30 to 10w-40 with 5w30 the suggested weight. I have to say the oil looked pretty dirty after its first oil change with M1 5w-30 @ 10k miles oci. It currently has rotella t6 5w-40 in her for the last 2k miles i figured it might help clean up the engine from the previous owner( all dino juice from the dealer at 7k miles) and might be a little more robust for the towing i was doing the last month. The truck currently had 86k miles on her.
So my question is what would be a good everyday oil for this truck? Would 5w30 M1 EP be a good choice or would something like a 0w-40 M1 be a better choice. I am going to have a UOA done at some point and see how the oil holds up but just looking for a good long OCI oil for now and a safe interval. After a couple changes to get it stabilized ill do some UOA's ans see how far i can push the OCI. Cost is not a real concern but i do like something i can pick up locally. Also i am in Greensboro NC as far a climate.
