WM Valvoline Full Syn Modern Eng Clearance
by Spartanfool. 03/22/19 04:22 PM
Need Moly basic training
by Bill_W. 03/22/19 04:03 PM
P0420 code goes away in warmer weather
by 2010Civic. 03/22/19 03:54 PM
Customer declined new belt
by Chris142. 03/22/19 03:13 PM
How to deep clean back of wheels?
by qdeezie. 03/22/19 02:51 PM
RK oil sale T4 15w40
by 1978elcamino. 03/22/19 01:57 PM
Hello and goodbye to my old job
by Motorking. 03/22/19 01:52 PM
Ichiro Suzuki retiring from baseball.
by PimTac. 03/22/19 12:40 PM
91 Caprice door wont fully latch...
by columnshift. 03/22/19 12:30 PM
Denso Platinum TT for 2004 Corolla?
by zorobabel. 03/22/19 11:16 AM
What should I run in the 09 rabbit trans
by ram_man. 03/22/19 10:32 AM
Chevy express van for towing
by Fitter30. 03/22/19 10:24 AM
Mobil 1 Filter Clearance - Wal Mart
by sdude2k2000. 03/22/19 10:01 AM
STP VI trans fluid
by acme. 03/22/19 09:37 AM
Increased oil capacity = lower pil temps ?
by SavagePatch. 03/22/19 09:15 AM
2007 Corolla - P0441 and P0455 codes
by Bama. 03/22/19 08:44 AM
Oldmoparguy1
by cjcride. 03/22/19 08:23 AM
Check engine light
by rtrdad. 03/22/19 08:21 AM
Super Tech 5W30 Synthetic With GDI Engine ?
by ChrisD46. 03/22/19 07:00 AM
Skendread, NGK, Thomas1, RE_Vision, JamesMc
67587 Registered Users
108 registered members (2015_PSD, 2K2AcuraTL, 14Accent, 92saturnsl2, 53' Stude, 240_Ed, 11 invisible), 2,084 guests, and 50 spiders.
Topics286,244
Posts4,905,150
Members67,587
Most Online2,967
Mar 10th, 2019
BMW E90 320d... .Oil recommendation #3903966
11/01/15 06:10 PM
11/01/15 06:10 PM
Greece
marios Offline OP
marios  Offline OP
Greece
Hello,
it's been awhile since the last time I posted on this forum, now I'm going to ask a common question on which Oil to use for my car.
I got a BMW E90 320d (N47D20A engine) with an upgraded performance Kit reaching now 217 HP.. ..
Up so far, I used Castrol Edge Oil, 0W30, 0W40 or 5W40 ones...now I'm reaching 60K miles on the car and thinking of getting a better Oil for the engine, with Oil change intervals at around 7500 miles (or 1 year, whichever comes first).
I've decided to use one of the following 4 oils, and I want to hear your thoughts about which one you would choose and why.
To help you with the climate I live, the temperature in my area is from -10 C in winter up to 40 C in Summer time.
These are the candidate oils:
CASTROL EDGE FST TITANIUM 0W-30
Pour Point: -57 C
Flash Point: 238 C
Density 838 kg/m (0.838 g/cm) at 15C
Viskosity Index: 170
Viscosity: Kinematic: 71 mm2/s (71 cSt) at 40C // 12.3 mm2/s (12.3 cSt) at 100C
CASTROL EDGE FST TITANIUM TURBO DIESEL 5W-40
Pour Point: -42 C
Flash Point: 202 C
Density 850 kg/m (0.85 g/cm) at 15C
Viskosity Index: 174
Viscosity: Kinematic: 75 mm2/s (75 cSt) at 40C // 13 mm2/s (13 cSt) at 100C
LIQUI MOLY TOP TEC 4100 5W-40
Pour Point: -39 C
Flash Point: 230 C
Density 855 kg/m (0.855 g/cm) at 15C
Viskosity Index: 169
Viscosity: Kinematic: 88 mm2/s (88 cSt) at 40C // 14,3 mm2/s (14,3 cSt) at 100C
ARAL SUPER TRONIC 0W-40
Pour Point: -60 C
Flash Point: 244 C
Viskosity Index: 171
Viscosity: Kinematic: 75.7 mm2/s (75.7 cSt) at 40C // 12.8 mm2/s (12.8 cSt) at 100C
PS: All the above oils have similar price, at around 13$/litre.
Thanks in advance.
BMW E90 320d (03/2008) PPK Edition (197 HP)
Re: BMW E90 320d... .Oil recommendation [Re: marios] #3903980
11/01/15 06:30 PM
11/01/15 06:30 PM
Coastal South Carolina
edwardh1 Offline
edwardh1  Offline
what does owners manual say
These products are all new every year?? They are a revolution!!! Razor blades, mens shirts, TVs, wiper blades, gutter guards, hearing aids... according to the ads. But also all new last year
Re: BMW E90 320d... .Oil recommendation [Re: edwardh1] #3903990
11/01/15 06:39 PM
11/01/15 06:39 PM
Greece
marios Offline OP
marios  Offline OP
Greece
Sorry, forgot to mention that all the above oils have the factory BMW specification LL04 needed .....so all of them can be used. ....
Basically, I'm looking for the one with the best specs as we see all 4 of them. ...
Re: BMW E90 320d... .Oil recommendation [Re: marios] #3904102
11/01/15 08:23 PM
11/01/15 08:23 PM
Toronto
dgunay Offline
dgunay  Offline
Toronto
I'd pick TD 5w40 if you live in Germany.
Why 5w40 instead of w30? Because there's no speed limit on German highways smile
2009 Acura CSX - PUP 0w20 / Fram XG7317 / Maxlife ATF
2018 Kawasaki Z650 - Motul 4T 5100 10w40 / OEM Oil Filter
Re: BMW E90 320d... .Oil recommendation [Re: dgunay] #3904313
11/02/15 01:17 AM
11/02/15 01:17 AM
Greece
marios Offline OP
marios  Offline OP
Greece
Well, I don't live in Germany but in a far more warm enviroment, I live in Greece (North Part).....
Re: BMW E90 320d... .Oil recommendation [Re: marios] #3906773
11/04/15 11:49 AM
11/04/15 11:49 AM
England
riggaz Offline
riggaz  Offline
England
I'd go for the 5w-40 or 0w-40 LL04 oil personally, nice wheels!
Re: BMW E90 320d... .Oil recommendation [Re: riggaz] #3906813
11/04/15 12:30 PM
11/04/15 12:30 PM
Greece
marios Offline OP
marios  Offline OP
Greece
Thanks for the answer.. ...which 5W-40? The Castrol or the LIQUI Moly?
Re: BMW E90 320d... .Oil recommendation [Re: marios] #3907796
11/05/15 09:47 AM
11/05/15 09:47 AM
England
riggaz Offline
riggaz  Offline
England
The Castrol is the tried and tested one, you can't go wrong with it and it's officially approved. In our workshop you'd be getting Total Ineo MC3 5w-40. It's turbocharged so just as important as the correct oil is operating the engine on light throttles until it reaches operating temp. BMW's eat turbos because people drive them too hard from cold so treat it gently and you'll get long life out of it.
Re: BMW E90 320d... .Oil recommendation [Re: marios] #4812442
07/12/18 04:34 PM
07/12/18 04:34 PM
Greece
marios Offline OP
marios  Offline OP
Greece
Hi there, it's been a long time since my last post here.
I still have the same car, BMW E90 320d PPK Edition 197HP (removed the remap, back to factory standards) and since my last post (3 years ago) I kept using the Castrol Edge Turbo Diesel 5W-40 one, on annual oil intervals (6-8.000 miles).
The last time though, last May, I decided to use the Liqui Moly Top Tec 4100 5W-40 one, just for a change.
I'm posting again the specifications of these two oils, just for comparison reasons.
Pour Point: -42 C
Flash Point: 202 C
Pour Point: -39 C
Flash Point: 230 C
What's your opinion on this oil type change? Anyone else using the Liqui Moly Top Tec 4100 5W-40 oil, to give me a feedback?
Re: BMW E90 320d... .Oil recommendation [Re: marios] #4820848
07/22/18 09:55 PM
07/22/18 09:55 PM
Colorado Springs
edyvw Offline
edyvw  Offline
Colorado Springs
IMO best LL-04 oil is Castrol 0W30 LL04. It is not imported in the US but in EU is available. It is true synthetic developed for BMW.
Other one would be Mobil1 5W30 ESP. I use M1 5W30 ESP and often drive in Las Vegas in summer where temperatures are creeping to 48c.
Do not forget that with thicker oil comes more resistance and with that more heat. What you need is HTHS above 3.5 and any LL04 will do.
But I would stick to those two I mentioned.
15' Toyota Sienna AWD (Mobil1 5W30 EP+OEM filter).
11' VW Tiguan 2.0T (Castrol 0W40+MANN filter)
Re: BMW E90 320d... .Oil recommendation [Re: marios] #4823270
07/26/18 12:52 AM
07/26/18 12:52 AM
Greece
marios Offline OP
marios  Offline OP
Greece
Thanks for the reply mate, I'll think about it (Castrol 0W-30).
