Fasttimez
Thread starter
Originally Posted By: mlatour
Coincidence or not,
my brand new in 2004 Dodge RAM 1500 4.7l 2WD was specced for 75W-140 in the "9-1/4" rear axle w/3.55 gears
as I live in a rather cool climate (Montreal) and never towed or hauled anything I figured a quality synthetic 75W-90 would
suffice and help with the lousy gas mileage and cold weather flow.
Diff. got a fresh fill of RedLine every 3 years.
After 10 years-120K miles, the rear axle started whinning badly at speed / at operating temp. as the pinion bearing went south.
By this point I tried switching to a mineral 80W-140 to delay repairs but it was still as noisy.
My new 2014 base model F-150 XL 3.7V6 specs 75W-140 and you can bet I won't 'experiment' with using a thinner gear lube in it.
I understand your point completely. Using the chart & doing calculations, my rear differential barely specs in the lower region of the 75w-110 category at low speeds, at high speeds it's at the bottom of the 90w range, almost a 85w. I returned the 75w-90 Valvoline oil & got some Amsoil Severe Gear 75w-110. This is what my axle specs out to be, not 75w-140. Ford just went up to the 75w-140 because the 110w is so odd ball nobody really makes it. The 110 range my axle falls in, used to be included in the old 90w category before it split into 110w & 90w. So that answers my question about why 90w was spec'd for years & then the change to 75w-140.
Coincidence or not,
