Amateur Paint Questions
by The Critic - 11/18/19 04:15 AM
What the..
by Mad_Hatter - 11/18/19 03:53 AM
Neighborhood Etiquette
by The Critic - 11/18/19 03:41 AM
AME 37330 Hub Cleaner for Impact Wrench
by The Critic - 11/18/19 01:54 AM
Plastic bag vs Car
by The Critic - 11/18/19 01:50 AM
Fram XG7317 20k miles cut open
by dbeau - 11/17/19 09:46 PM
2021 Ford Mach-E Electric SUV
by KeithS_NW_Ohio - 11/17/19 09:05 PM
Walker mower Oil
by Joey737 - 11/17/19 09:03 PM
Rough service tough light bulb 1¢ at Home Depot
by JLawrence08648 - 11/17/19 08:40 PM
2015 F150 5.0; 10w-30/5w-40 mix 8.6k miles
by Buzzinhalfdozen - 11/17/19 08:36 PM
MOPAR MO-285 FACTORY OIL FILTER CUT OPEN
by 53' Stude - 11/17/19 07:43 PM
Best Garage Door Seals
by Gebo - 11/17/19 07:18 PM
Bar oil as fogging oil
by WA1DH - 11/17/19 06:47 PM
Fram PH2 ExtraGuard Cut Open
by A310 - 11/17/19 06:38 PM
C&P Pentius UFXL PH16-equiv.
by 92saturnsl2 - 11/17/19 06:18 PM
Fleetguard WF2074 Coolant Filter Cut Open
by Pyrotechnic - 11/17/19 05:24 PM
Cuts on tire sidewall
by mclasser - 11/17/19 03:19 PM
Hyundai Theta II Engine in Newer Years
by smc733 - 11/17/19 02:41 PM
Walmart deals
by Deere John - 11/17/19 02:33 PM
leafuntec, wolf777, Smittyzzz, JimBobSeeker, Joey737
69902 Registered Users
51 registered members (AurionX2, Amkeer, Aichiguy, 77GrandPrix, 2015_PSD, 65convertible, 5 invisible), 870 guests, and 17 spiders.
Topics297,573
Posts5,118,290
Members69,902
Most Online3,589
Nov 2nd, 2019
Page 2 of 4 1 2 3 4
Re: Auto-Trak II fluid alternative??? [Re: MolaKule] #3897365 10/26/15 03:04 AM
T
Turk Offline
T
Originally Posted By: MolaKule
The Auto-Trak II fluid is a 7.3 [email protected] fluid (same viscosity as DexronIII/Merc) with a special friction modifier.
Elemental Analysis (what you can see in a $28 analysis):
Boron - 150 ppm
Calcium - 40 ppm
Phos - 300 ppm
Silicon - 3 ppm
Quote:
I would would say any synthetic ATF would be an excellent replacement at a better value.
Better think again.
Good advice MolaKule. I changed my 2003 Sierra 4x4 Xfer Case Fluid 3 times now in 200,000 miles (on it's 4th fill).
Zero problems and I'm not easy on the drivetrain......
03 GMC Sierra 4x4 200k M1 0-40+PU
00 Saturn SL2 89 YO Lady Car 92k, Edge Ext
98 Saturn SC2 Rare "Red Hot" 165k, Edge Ext
97 Camry 245k, Maxlife
Re: Auto-Trak II fluid alternative??? [Re: SavagePatch] #3898065 10/26/15 05:23 PM
MolaKule Offline
Global Moderator
Global Moderator
Originally Posted By: SavagePatch
Originally Posted By: xxch4osxx
For how little you have to change out the transfer case fluid, I would stick with Auto Trak 2.
To play devil's advocate and to add to the conversation...
With this opinion shouldn't we all stick with OEM atf in our automatic transmissions too? Especially since it's even less often that it needs to be changed out? Lots of people, including myself, use multi-vehicle ATF's like Maxlife ATF and RP MaxATF in our transmissions with no hesitation and no issues. It's my understanding that an automatic transmission is a lot more complicated of a beast than an automatic or manual transfer case.
I see your point but don't think one can necessarily draw that kind of conclusion.
This TC has need of specific friction modification. Now Valvoline may well have developed a TC fluid with a spread of friction coefficients that may work well in the three units they claim they cover.
For AT's there are only about 3 or 4 clutch material manufacturers. Many of these materials are similar.
The main differences are found in the programming (timing) of gear changes with engine speed and torque, and clutch/band pressures.
In terms of MaxLife ATF, I think they have done a good job of finding workable dynamic friction coefficients that cover most of the clutch materials, timing, and pressures used.
"Dr. Larry Fleinhardt:
You know that it's considered unsolvable?
Charlie Eppes:
Well, certainly people who have failed to solve it might think that." From NUMB3RS
Re: Auto-Trak II fluid alternative??? [Re: Loobed] #3899180 10/27/15 06:09 PM
F
FastLane Offline
F
Its been replaced by Dextron VI in the new trucks.
2010 Silverado 4.8 4x4 Mobil 1 5W30 Fram XG10060
2002 Mustang GT 4.6 Mobil 1 5W30 Fram XG2
1966 Cessna 150 Phillips 20W50
2013 Mercury 30hp Mystic 25W40
Re: Auto-Trak II fluid alternative??? [Re: FastLane] #3899230 10/27/15 06:58 PM
M
MrHorspwer Offline
M
Yeah, the fluid has been replaced... along with the rest of the transfer case.
Why would the OP care what a completely different transfer case uses for fluid?
Re: Auto-Trak II fluid alternative??? [Re: MrHorspwer] #3900063 10/28/15 02:05 PM
F
FastLane Offline
F
I'm not sure what transfer case he has. In 2010 auto trak was used. 2012 it's dexron vi. Same t case as far I know. My 2010 isn't automatic which just uses dexron vi. I bought auto trak fluid for the 2012, then read the owners manual...... Dexron Vi.
Re: Auto-Trak II fluid alternative??? [Re: Nyogtha] #3900067 10/28/15 02:10 PM
Sunnyinhollister Offline
Originally Posted By: Nyogtha
Valvoline offers an aftermarket alternative - Valvoline Transfer Case Fluid.
http://www.valvoline.com/our-products/au...sfer-case-fluid
http://content.valvoline.com/pdf/transfer_case_fluid.pdf
I was hoping this would work in my Borg Warner BW44-44 transfer case on my Ram but Valvoline said they don't have a fluid that crosses for the Borg Warner transfer case.
I see O'Reilly carries it.
http://www.oreillyauto.com/site/c/detail...3&ppt=C0207
The Valvoline fluid is awfully thin @5.91 [email protected] 100C
2017 Ram 1500 Regular Cab 4x2 5.7L 8spd
2017 Chevy Bolt
2018 Jeep Cherokee Trailhawk
2004 Toyota Highlander AWD - RIP
2001 Ranger XL 4x4
Re: Auto-Trak II fluid alternative??? [Re: Loobed] #3900161 10/28/15 03:25 PM
N
Nyogtha Offline
N
Compared to which other transfer case fluids?
"No matter how paranoid you are you're not paranoid enough. Tell the truth. Reach as many people as you can with it. That's your weapon." - Susanne Modeski, aka "Holly" to The Lone Gunmen
Re: Auto-Trak II fluid alternative??? [Re: Loobed] #3900170 10/28/15 03:29 PM
G
Greasymechtech Offline
G
Compared to Dex/Merc/ATF+4...
I was eyeing it for a couple transfer cases but will go thicker.
At what point should a lurker start posting :-)
Re: Auto-Trak II fluid alternative??? [Re: Loobed] #3900534 10/28/15 08:36 PM
N
Nyogtha Offline
N
I reckon it's kinda like Dex6 / Merc LV / Maxlife ATF - because they don't shear down like DexIII/Merc
Re: Auto-Trak II fluid alternative??? [Re: Loobed] #3900559 10/28/15 09:07 PM
Snoman002 Offline
Are you experiencing the shudder when turning tight? If so you need to change the fluid, run it for a while, then change again (gm recommended procedure). At $9 a bottle and 2 bottles flush it's not inexpensive.
That said, it's a questionable call, and this isn't a cheap 203 transfer case either. Personally I would just use the GM stuff, it's proven to work and work well, and in reality there is little to be gained here other than possibly a few bucks.
Re: Auto-Trak II fluid alternative??? [Re: Loobed] #3900646 10/29/15 12:27 AM
N
Nyogtha Offline
N
I found the OEM fluid at Napa, slightly cheaper than the Valvoline fluid at O'Reilly.
http://www.napaonline.com/Catalog/Catalo...4017_0190428884
However the Valvoline fluid is advertised as a full synthetic. As previously noted the vis similar to full synthetic Dex 6 & Mercon LV.
Re: Auto-Trak II fluid alternative??? [Re: Loobed] #3900658 10/29/15 12:49 AM
N
Nyogtha Offline
N
Heck it's even $8.99 / qt. at O'Reilly
Re: Auto-Trak II fluid alternative??? [Re: Nyogtha] #3900669 10/29/15 02:20 AM
R
Rendezvous Offline
R
According to a transmission engineer at Chrysler I spoke to he said the BW 44-44 & 44-46 fluid is just DexIII. He told me he even confirmed it with one of the transfer case engineers there.
Re: Auto-Trak II fluid alternative??? [Re: Loobed] #3901030 10/29/15 10:50 AM
N
Nyogtha Offline
N
Interesting. Have you run DexIII in one of those transfer cases? If so for how long and how well did it work?
I've contacted Valvoline, SOPUS (via Gena Fishbeck), and Royal Purple and all those companies said they have no fluid to replace Mopar Part No. 68089195AA. All those companies make an ATF that crosses for DexIII.
The OEM fluid is $30 / qt. at the closest dealer. I've found it on-line for about $20 / qt. including shipping.
The FF in my transfer case is red, but the Mopar fluid is reported to be green.
Re: Auto-Trak II fluid alternative??? [Re: Nyogtha] #3901077 10/29/15 11:45 AM
R
Rendezvous Offline
R
Yes I have Redline D4 in my Borg Warner 44-46 which is a DexIII replacement. I put it in at about 18k and currently have 38k on the truck. When I drained the factory fill out of the T case it was red. A friend of mine has the same truck and he bought the Mopar fluid from our local dealer and when we put it in it was red also. A while back I was thinking about sending a sample of it to Blackstone just to see. However after being told it was DexIII I didnt bother since I trusted the person who told me.
Page 2 of 4 1 2 3 4
