Originally Posted By: The_Eric
Originally Posted By: cat843
How many shops use a dial gauge on brake rotors?
Mine. I start off by cleaning the bearing hub surface, washing the (new) rotor in hot, soapy water with a Scotch Brite and finishing with a rag. Rinse and blow them dry. Then I apply a layer of anti-seize to the inside of the rotor hat and tighten them down using cone washers in between the rotor and lug nut. I typically shoot for .002" or less run out, and it's not uncommon to need to re-index them on the bearing hub to achieve it. Every now and again I'll get one that simply won't go in spec and the bearing hub is to blame. It's not often it happens, so I don't typically check them.
Originally Posted By: ford46guy
Some parts of the article are correct but you have to realize it is written or endorsed by a company who sells many millions of imported rotors! With today's rotors you need to be ultra vigilant that torque specs and patterns are observed and runout is minimized. Old rotors were much heavier and newer cars try to minimize material to save gas.
That's not my experience. Rotors seem to be getting bigger and beefier. Look at a rotor from an 80's or early 90's car of truck and compare it to the same model car or truck from a much later year. BIG difference! Bigger in diameter and thicker braking surfaces too.
Pablum. Off the top of my head, the front rotors on my Caddy (same as a 9C1 Caprice) are BIG. Though only 12" diameter (had to fit in a 15" wheel), they are about an inch thick and, more to the point, they are probably 25lbs of cast iron, which makes for a nice heat sink!
My Magnum's rotors, though a bit bigger (320mm, about 12.5"), were lighter...and warped very easily! (I put a caliper on them: they were WARPED.)
