- Joined
- Nov 29, 2009
- Messages
- 7,262
I've always used stanadyne lubricity formula which is supposed to clean and lubricate, but I was noticing it skipping slightly at idle when hot listening to the exhaust. Not sure if that's what it was since the truck runs smooth. Also for a while I did just use it for running around doing short trips a bunch and noticed it would smoke a good bit under moderate acceleration. I think it got carboned up a bit cause I started towing a trailer around almost everywhere and I think the constant higher egts cleaned out whatever carbon buildup there was cause it pretty much stopped doing the smoke and the mis. Just curious if anyone has had success with diesel clean cleaning injectors? Thinking about using it, but at the same time I've already been using stanadyne all along so I don't know. Thought?
