I had some parts made in China that have failed me and I thought I would rant about what has and what has not worked out for me.
I had a made in China Cardone water pump that was on for about 20,000 miles. The seal was great but the bearing started making a roaring noise under acceleration.
My Honda OEM axles developed a feeling as though my wheels were going to fall off so I put on O'reilly auto new made in China axles. I developed a vibration and thought I would switch brands. I installed Cardone new axles and I had a vibration at a different speed. I then installed remanufactured Honda axles and all problems are gone.
I've had motor mounts made in Taiwan (a republic of China) from Beck/Arnley and they tore in less than 10,000 miles. Replaced with OEM Honda and the mounts have over 30,000 miles on them and look great.
I will say that the ignition switch from O'reilly Auto called Import Direct is made in Taiwan is holding up well. I've had the switch for about 2 years with no problems.
I also have a blower motor resistor (Duralast) from Autozone that is made in Taiwan which has worked well for the past 5 years.
Sorry, but I must also rant about India. I had strut mounts, Moog and Kyb, that were made in India and both of them had rubber pieces flake off them; in addition, they developed a ringing noise going over bumps that took me a long time to troubleshoot. I replaced them with OEM Honda mounts and bearings and the noise is gone.
