Top Tier Gas Again
Agreed.
I have contacted Shell and am waiting for an update.
I'm not interested in burning anyone. I'd just like to know the truth.
I can't believe that we have no gas station owners on here.
I will tell you that I have bailed from Shell until I joined here. What I have noticed is my local Shell is now competitive with all the other stations. Before it was always much higher.
I used an "Extreme" gas station for years. For some reason all of my cars run great on it and get excellent MPG. Since I switched to Shell my MPG is down amongst other things. I don't blame Shell's gas because I'm convinced I'm not getting Shell gas- ever!
Originally Posted By: Scum_Frog
I think much like we have had Industry reps ( Pennzoil, Gumount) on the site to do a Q&A it would be great to have a Gas rep, preferably a Top Tier gas company to do a Q&A to put this debate to rest.
I like many other are becoming skeptical about this whole Top Tier thing. There are only so many Fuel Terminals to supply a given market.
I'd be interested is seeing the Q&A if it could ever be arranged.
Best bet is to go with Costco.
Their system means that not only are you getting the additive, but it's been properly mixed.
Read this from 2004.
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=277725
Originally Posted By: fuel tanker man
I've been in the petroleum hauling business for over ten years now. We haul exclusively to one customer from various oil terminals in the Virginia/North Carolina area. I've been authorized to load at over a dozen terminals in a 300 mile radius in recent years. I occasionally still drive, but my normal job is dispatching ten tanker trucks to our area stations.
What I can tell you about "branded" gasoline is this: Sometimes it ain't what you think it is. And the additives which are put into the branded gasolines are added in such small amounts it may or may not have the advertised effects on your engine/fuel system.
Of course the states regulate the octane advertised on the pumps, but no agency (to my knowledge) ever checks for the additives which are purported to be present in the branded gasolines.
It then becomes possible for branded stations to sell gasoline which doesn't have the additives that the signs and commercials say that it has. This can occur when the additive injector system fails at the loading terminal, or when the terminal runs out of an additive.
Additives in gasoline are just like additives in oil; they are "added" to the base product. All gas begins as pretty much the same stuff. Regular unlead and premium for all oil terminals in a given area comes up the same pipeline. We pull off of Colonial Pipeline in this area, and a small bit off a branch pipeline called Plantation Pipeline. When Citgo, Chevron, Conoco, Amoco, Texaco, Shell, and the rest fill their huge terminal storage tanks the gas comes off the same pipeline at pretty much the same time. There is one exception: Amoco Ultimate Premium is refined an extra step, and it comes up the pipeline all by itself.
Other company's 93 octane premium fuels (I don't know anything about Sunoco fuels as they aren't distributed in my area) are the same before the additives are injected into the gasoline when it is being loaded onto the transport tanker trucks.
There are a couple of different octanes out there for what can be called "premium" gasoline. Read the pump. If it's 92, that ain't bad. 93 is better. If it's 91 I'd definitely pass. The lower octane premiums are simply cut a bit with regular unleaded. That's also where "midgrade" or "plus" gasoline comes from; it's mixed as it goes on the tanker truck--35 percent premium and 65 percent regular in most cases.
The quality of gasoline in the pipeline must meet certain standards, of course. This doesn't mean it will always be exactly the same, however.
It is possible that your car will respond well to one particular company's additive. It's possible, but I think if you really tested the notion well you'd find other explanations for why your performance and/or mileage was up/down based on your choice of gasolines. I do know that Chevron's Techron works when I pour 12 ounces into my car's tank, but I don't know if the concentration of Techron in Chevron's gasoline is high enough to really do much. Think about it: If that stuff is actually worth fifty cents an ounce, and the recommended dose is about one ounce per gallon of fuel in your tank, it would run the cost of the Chevron branded gasoline up way too much to be competitive. Unless, of course, there are only trace amounts of the Techron in the branded gas, which is the case.
When you get into unbranded gasolines you're in a "whole 'nother world." Unbranded gasoline can come from any terminal out there. It's the cheap gas of the day. This doesn't mean that the gas is no good, it simply means that if Conoco/Phillips has the best gasoline price of the day, it's a safe bet that's where your local Racetrack, Sheetz, Wilco/Hess, or fill in the blank got their fuel from.
Most of us cannot tell any real difference between Shell branded or Chevron branded gasoline and what our local chain convienience (unbranded) stores sell. And that's not surprising since the base fuel is exactly the same stuff. Shell, Chevron, and unbranded gasolines all comes up the pipeline at the same time; it's the same stuff. Only the miniscule additive package makes it any different.
We've all heard "Don't buy _______ gas because they put water in it." This is absurd for more reasons that I've got time to sit here and type out. But the most glaring flaw in this twisted logic is that gasoline and water don't mix. The water settles to the bottom of the tank. The sumps are set at 12 inches off the floors of oil terminal holding tanks and water checks are made daily (and required by law). It's nearly impossible for water to be loaded onto a gasoline tanker truck and subsequently delivered to the customer.
If you do find water in a retailer's gasoline, it got there by leaking into his ground tanks. This does happen, of course. Most newer stations have Veeder-Root tank monitoring systems these days. This system will sound an alarm if water is present in the ground tank.
So basically I just shop price for my personal gasoline. There's a chain in this area called "GO-Mart" which tends to keep the prices down. I rarely buy a full tank of gas from any branded retailer anymore. While the additives that the big gasoline retailers use are only used in very, very small amounts, they are in there. And this (along with national advertising campaigns) runs the cost of the branded gasolines up. And since I can't see any difference in my vehicles I can't justify the higher prices of the branded gasolines.
If I could recommend purchasing gas from any retailer, I would say go to the retailer that moves the most gasoline. His tanks are probably the cleanest. His gasoline is probably the freshest off the pipeline. His ground sump and dispenser filters are going to be changed much more often. Since his business plan is obviously to sell maximum volume, he'll be meticulous in keeping filters maintained, and he'll have a fuel tank monitoring system (the Veeder-Root system mentioned earlier) which will alert him if water is ever present in his tanks.
Dan
Originally Posted By: AirgunSavant
We talked about it last week where in my area all the top gas retailers use the same fuel service, An independent wholesaler.
I have no faith in the Top Tier website. I have investigated my local retailers and
came to the conclusion that it means very little.
Yesterday I talked to my local Shell gas station owner. He told me that he is not obligated to buy Shell gas. He too uses that independent fuel service on occasion for whom I called and they sell one gas. Offer no differing additive packs and only different octanes.
The Shell owner said he looks for deals on gas and uses Shell but when he runs out and they can't deliver quickly enough or get too pricey, he gets it where he can. He said it's that way everywhere.
Preparing for a beating.......
So he admits to being unethical and a crook. If he cheats on Top Tier he probably cheats on the octane level also.
Shell like the rest pays about $30K to be a TT seller- they claim that's the "testing fees" so no [censored] there.
Originally Posted By: Nate1979
Shell is TT. TT doesn't add cost but ensures you are getting a quality fuel. This thread is b s.
Don't forget the annual fee based on the # of retailers.
Dan
I'd say "fuel tanker man" has a good grasp of the situation.
