Originally Posted By: Falken
I would guess the fuse in the outlet would blow first, as it probably under the dash, and closest to the battery.
The resistance out to the inflator would probably reduce the amount of current that fuse gets compared to the outlet fuse.
So, if both fuses are IDENTICAL, I would say the outlet fuse would blow first.
But this is just a guess on my part.
Nope, current would be constant throughout the circuit, but voltage would drop as you got closer to the load due to resistance in the wire. (So I don't know which fuse would blow first. Probably the one with the lower actual, not nominal, ampacity - although they're rated the same, there are likely manufacturing variations.)
