P0171 and P0174
by NavyVet88 - 01/26/20 05:04 AM
Essex Engine Plant (Canada)
by BlueOvalFitter - 01/26/20 03:18 AM
Mopar oil bottles
by Franz - 01/26/20 12:47 AM
Ultra-rare barn find!
by Toy4x4 - 01/26/20 12:11 AM
2015 Hyundai Genesis 5.0L Review
by Nick1994 - 01/25/20 11:56 PM
My doggie had a rough week
by Chris142 - 01/25/20 11:26 PM
Delivery meal kit review - Dinnerly vs HelloFresh
by pezzy669 - 01/25/20 10:32 PM
Eotech Vudu scopes
by OVERKILL - 01/25/20 10:10 PM
'12 Civic burning oil after switch to M1
by sr20detfwd - 01/25/20 09:33 PM
Wix/NAPA Gold and M+H
by Uphill_Both_Ways - 01/25/20 09:06 PM
New seafoam oil stabilizer at AZ
by Chesterr - 01/25/20 08:13 PM
In 3 hours - 730 days and counting
by OVERKILL - 01/25/20 08:12 PM
Pig Parker!
by dishdude - 01/25/20 07:58 PM
NGK Conventional vs. Ruthenium Plugs
by doitmyself - 01/25/20 07:58 PM
Container or funnel?
by Philthy_Phil - 01/25/20 07:24 PM
AC Delco filters at Amazon as little as $1.07
by jayjr1105 - 01/25/20 06:22 PM
Excessive moisture in oil
by mb32 - 01/25/20 05:47 PM
Cover for Jeep + Trailer
by kehyler - 01/25/20 05:34 PM
kwashabcp, ronster, BackToReality, Scopeman, M635_Guy
70527 Registered Users
48 registered members (Char Baby, alchargo, BobsArmory, bmod305, blufeb95, bradepb, 3 invisible), 1,180 guests, and 17 spiders.
Topics300,572
Posts5,178,518
Members70,527
Page 1 of 6 1 2 6
the worst oil change? #3889519 10/18/15 06:24 PM
02FocusZX5 Offline OP
does first oil change at 30 miles
factory fills are trash
synthetic is inferior to conventional
engine is machining itself?
toyota recommends 0w-20. puts in 5w-30.
Re: the worst oil change? [Re: 02FocusZX5] #3889524 10/18/15 06:28 PM
spasm3 Online Happy
Online Happy
Back at cha!
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
Re: the worst oil change? [Re: 02FocusZX5] #3889542 10/18/15 06:42 PM
F
Falken Offline
F
Did he mention if it was the Special Edition?
Re: the worst oil change? [Re: 02FocusZX5] #3889553 10/18/15 06:53 PM
69GTX Offline
I've done many frequent early oil changes at 500-800 miles, synthetics included. And even though the oil looks clean and bright (honey bronze) on the dip stick and also when pouring out in the light....it looks dark in the oil waste pan. I wonder if that could be because the background is black plastic? I recommend a white one in the future.
Wouldn't you expect some metal wear particles on that first break in, even at 30 miles? At some point this engine was run for the first time bone dry of oil everywhere beyond the oil pump. The result of that will show up in the brand new oil. If the OEM recommends 20 weight why use a 30 weight on a brand new car?
2001 Lincoln Cont 4.6L DOHC/ 50K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: the worst oil change? [Re: 02FocusZX5] #3889554 10/18/15 06:54 PM
J
JEL01 Offline
J
I think I'll make an oil change video for the RX350, 20w50 ought'a do it, 0w20 is just too thin! oilburner
Cars I maintain:
02 Mercedes CLK430
09 Honda Accord V6
13 Lexus RX350 AWD
02 Toyota Tundra 4x4
18 Lexus GX460
Re: the worst oil change? [Re: 02FocusZX5] #3889561 10/18/15 07:00 PM
dlundblad Offline
5w30 in a 0w20 spec'd engine?
You found Merk's garage DIY channel! laugh
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 195k M1 0w40 Mahle OX149D
97 Chvy Blazer 4.3 158k M1 EP 10w30 Supertech ST3980
Re: the worst oil change? [Re: 02FocusZX5] #3889564 10/18/15 07:01 PM
N
NormanBuntz Offline
N
Amazingly this hack must be so much smarter than Toyota's engineers.
Firesign Theater: "Heavy on the 30 weight, Mom."
2017 Toyota Camry XLE, 11K, 2nd owner
2007 Honda Ridgeline RTS, 96K, 1st owner
2007 Infiniti M35, 115K, 1st owner
Re: the worst oil change? [Re: 69GTX] #3889565 10/18/15 07:01 PM
J
jr047 Offline
J
It's because you're looking through more of the oil, as compared to on the dipstick or even in the stream coming from the drain hole. There is more oil between the light source and your eyes, so less light passes through it. It's the same reason some clouds look black while some appear to be white. If a cloud is more dense than another, less light passes through, so the cloud appears to be darker.
(I didn't watch the video; my apologies if this was in reference to, or mocking, something in the video.)
Re: the worst oil change? [Re: 02FocusZX5] #3889568 10/18/15 07:02 PM
H
hansj3 Offline
H
Dnf, too dumb. Could not stand all of his kooler outs and back at yas
Re: the worst oil change? [Re: jr047] #3889580 10/18/15 07:13 PM
69GTX Offline
The bigger effect here with new oil is the dark background of the waste oil receptacle. Take fresh oil and pour some into the standard 1 qt cap with white background. It looks honey bronze. Now do the same thing with a black cap with black bottom. It looks black now. This is part of the "science" that the guy in video used to condemn this factory fill. How much light gets reflected off a black vs. white surface? I'd also estimate that the depth of 4 qts of oil in the waste pan (see video) is about the same thickness as what's pouring out of the oil pan (3/8-1/2"). One is honey and one is black...same oil. I agree there are 2 effects. It's like looking through 20 ft of water above Bahamian white sand bottom.
1969 Ply GTX/RRs
Re: the worst oil change? [Re: 02FocusZX5] #3889595 10/18/15 07:25 PM
N
Nate1979 Offline
N
Not ever changing the oil would be the worst. This is a minor detail and at least the oil was changed.
2015 GMC Sierra 2500 6.0L
2010 Subaru Forester 2.5X
Re: the worst oil change? [Re: 02FocusZX5] #3889605 10/18/15 07:33 PM
spasm3 Online Happy
Online Happy
Really the only really questionable thing he is doing is using a heavier oil. Is that oil acceptable in the manual? My elantra allows 5/20 and 5/30. Conventional changed appropriately is not a problem, he just has some odd idea about synthetic.
Re: the worst oil change? [Re: 02FocusZX5] #3889609 10/18/15 07:35 PM
G
GiveMeAVowel Offline
G
The engine is machining itself? crackmeup
A waste of his time, and perfectly good oil too!
That stuff he sees is what is removed by the oil filter
before it reaches the engine.
As far as oil weight, I agree that 5w-30 is probably the most all around robust for this model but due to the warranty I would have kept the Toyota recommended weight in it.
Why he would use dino in a car that is engineered from the get go for synthetic is beyond me. Seems silly.
Re: the worst oil change? [Re: 02FocusZX5] #3889618 10/18/15 07:39 PM
dgunay Offline
He should have mentioned that it's a 2016 Toyota Corolla S Special Edition. What a moron!
2009 Acura CSX - PUP 0w20 / Fram XG7317 / Maxlife ATF
2018 Kawasaki Z650 - Shell Rotella T4 15w40 / OEM Oil Filter
www.autoandroad.com
Re: the worst oil change? [Re: 02FocusZX5] #3889620 10/18/15 07:41 PM
R
redhat Offline
R
The 2014 Civic we have will be getting Edge and TGMO 0W-20 for it's next couple OCIs as that's what I've got. No fear of the 0W or 20 here.
But I do like my T6 in the Accord. Maybe if I didn't make that engine cry all the time...
19 F150 2.7 - M1EP 5W-30, FL2062, 11k
17 Taurus Limited AWD - M1EP 5W-20, FL500S, 30k
84 JD 316 Repowered w/Vanguard 18
Page 1 of 6 1 2 6
