Moose016
Thread starter
So the conclusion from Valvoline was the following:
"the sample results have made their way back to me.
The waxy build up you see with-in the oil is the detergents and somehow, water or moisture has gotten into the containers. When this occurs, the detergents bond with the water to form this waxy substance. If installed into an engine, the minimal water that was introduced to the oil would burn off and the detergents would blend back into the oil as the should once the engine had reached operating temperature."
No idea how the moisture got into the bottle, but they sent me 12 bottles of full synthetic high mileage with maxlife oil. Pretty good responsiveness from them, so I'll continue using Valvoline oil in the future, maybe not stockpiling it though.
