M1 HM 10w-30 vs M1 FS 0w-40
by RDY4WAR. 03/20/19 10:04 PM
Need Recommendations For A New SUV
by Dwight_Frye. 03/20/19 08:50 PM
GE dishwasher clicking
by silverrat. 03/20/19 08:20 PM
Every 6 months or one year OCI
by asker123. 03/20/19 07:36 PM
Valu Home Ctr. Peak Oil $9.94/5 qt jugs
by Nickdfresh. 03/20/19 07:32 PM
Chemical fire in texas
by Fitter30. 03/20/19 07:09 PM
PZ 37 CUT OPEN
by 53' Stude. 03/20/19 06:42 PM
Lube Intervals
by NibbanaBanana. 03/20/19 06:41 PM
When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
FYI: Costco is now stocking the 'good' Techron
by mbz321. 03/20/19 12:32 PM
Auto maintenance advice from a locksmith?
by Variant_S. 03/20/19 12:18 PM
DarkFrontier, Zuraxus, Burks21, GG16v, fleetwood62
67572 Registered Users
87 registered members (928, bbhero, AndyB, AlaskaMike, ammolab, Alfred_B, 11 invisible), 1,641 guests, and 58 spiders.
Topics286,168
Posts4,903,469
Members67,572
Most Online2,967
Mar 10th, 2019
Toyota 0w20 syn 10756 mil on oil 2012 Prius 40k #3877033
10/06/15 03:26 PM
10/06/15 03:26 PM
New York, NY
szgabor Offline OP
szgabor  Offline OP
New York, NY
It was the toyota dealer stock 0w20 synthetic oil. 10756 miles mostly summer highway. The car has now little bit over 40k. Prius has a 1.8L Atkinson cycle gasoline engine.
ALUMINUM|3
CHROMIUM|0
IRON|5
COPPER|1
LEAD|0
TIN|0
MOLYBDENUM|40
NICKEL|0
MANGANESE|0
SILVER|0
TITANIUM|0
POTASSIUM|0
BORON|7
SILICON|8
SODIUM|9
CALCIUM|2301
MAGNESIUM|11
PHOSPHORUS|564
ZINC|683
BARIUM|0
SUS Vis @ 210F|53
cSt Vis @ 100C|8.19
Flashpoint F|400
Fuel %|<0.5
Antifreeze %|0.0
Water %|0.0|
Insolubles %|0.3
Seems nothing out of normal to me. Any comment would be appreciated.
Re: Toyota 0w20 syn 10756 mil on oil 2012 Prius 40k [Re: szgabor] #3877051
10/06/15 03:32 PM
10/06/15 03:32 PM
NY
Benito Offline
Benito  Offline
NY
That's definitely not normal!
You may not control all the events that happen to you, but you can decide not to be reduced by them. - Maya Angelou
Re: Toyota 0w20 syn 10756 mil on oil 2012 Prius 40k [Re: szgabor] #3877054
10/06/15 03:33 PM
10/06/15 03:33 PM
Kendall, FL
wemay Offline
wemay  Offline
Kendall, FL
Great report!
18 KIA Sportage 2.4 AWD
M1HM 10W30, OEM
13 Hyundai Santa Fe Sport 2.0T
PPeL 5W30, OEM
Re: Toyota 0w20 syn 10756 mil on oil 2012 Prius 40k [Re: szgabor] #3877077
10/06/15 03:48 PM
10/06/15 03:48 PM
Northern Kentucky
901Memphis Offline
901Memphis  Offline
Northern Kentucky
Very nice low wear metals in the oil
2012 Chevy Cruze LT 1.4T - 59k - Edge 0w30 SL + Mahle OX401D
2002 Buick Century 144k - Built 4T65e(Maxlife) - GTX 5w30 + Fram XG3980
Re: Toyota 0w20 syn 10756 mil on oil 2012 Prius 40k [Re: szgabor] #3877079
10/06/15 03:51 PM
10/06/15 03:51 PM
New York, NY
szgabor Offline OP
szgabor  Offline OP
New York, NY
Tried to add to the original post but I cannot edit that ....
but here it is ... (I also have the pervious 4 report in a table form but not sure how to copy it here ... some code I guess
[img:center]http://tinypic.com/view.php?pic=312v4tz&s=8[/img]
image of the report
I give up to actually put an image here only links seem to work .... should be easier
Re: Toyota 0w20 syn 10756 mil on oil 2012 Prius 40k [Re: szgabor] #3877097
10/06/15 04:04 PM
10/06/15 04:04 PM
NY
Benito Offline
Benito  Offline
NY
Re: Toyota 0w20 syn 10756 mil on oil 2012 Prius 40k [Re: szgabor] #3877139
10/06/15 04:37 PM
10/06/15 04:37 PM
Colorado
lubricatosaurus Offline
Colorado
With all that start-stop going on with the engine, your iron ppm should be off the charts big. How is Toyota able to keep ring, cylinder, and cam lobe wear down so low? What manner of sorcery are they using? I think I remember seeing other Prius UOA reports like this that look stellar as well.
Only comment: Use a Fram toughGaurd oil filter or Mobil1 oil filter and see if you can't get the insolubles down. Fram Ultra not available for your application.
Re: Toyota 0w20 syn 10756 mil on oil 2012 Prius 40k [Re: szgabor] #3877141
10/06/15 04:39 PM
10/06/15 04:39 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
Looking good boss man. What's for dinner tonight?
Re: Toyota 0w20 syn 10756 mil on oil 2012 Prius 40k [Re: lubricatosaurus] #3877144
10/06/15 04:42 PM
10/06/15 04:42 PM
NY
Benito Offline
Benito  Offline
NY
Thin oil flows faster, keeps engine cooler, sprinkle in some pixie dust and add unicorn tears, but then you find the dealer wasn't using genuine TGMO 0w20 after all.
And there would be zero wear with 25w70. crackmeup
Re: Toyota 0w20 syn 10756 mil on oil 2012 Prius 40k [Re: Benito] #3878827
10/08/15 09:55 AM
10/08/15 09:55 AM
New York, NY
szgabor Offline OP
szgabor  Offline OP
New York, NY
And in the prius the engine doesn't really work at low rpm's SCANGAUGE shows nothing less 960 so no load ever on low rpm.
Re: Toyota 0w20 syn 10756 mil on oil 2012 Prius 40k [Re: lubricatosaurus] #3880638
10/09/15 09:20 PM
10/09/15 09:20 PM
CA
The Critic Online crying
The Critic  Online Crying
CA
I wouldn't - the OE filter is less than $4 (when purchased by the case) from the dealer, and the filter has been validated for 10,000 mile intervals by Toyota. The Fram costs significantly more and there is no guarantee that any small reduction in insolubles will actually translate to anything meaningful.
2011 Toyota Prius 1.8L - 185K - SuperTech Dexos Full Syn 0W-20
2007 Honda Accord 2.4 - 135K - Mobil 1 EP HM 5W-30
Re: Toyota 0w20 syn 10756 mil on oil 2012 Prius 40k [Re: szgabor] #3883338
10/12/15 06:09 PM
10/12/15 06:09 PM
Austin, Texas
Brons2 Offline
Brons2  Offline
Austin, Texas
changed it too soon. try 15K.
2012 Hyundai Sonata GLS 6MT 2.4GDI, ProDS 10w30, XG9688 filter, 2018 Mitsubishi Outlander SEL 2.4 CVT, Factory fill still.
