supertec cartridge filters
by super20dan - 01/19/20 06:17 PM
More Valvoline on rollback at WM
by jayjr1105 - 01/19/20 06:13 PM
Crossed poles on jumper cables
by 3Aone - 01/19/20 05:33 PM
Napa Gold 7060 7.5K miles
by KenshinHimura - 01/19/20 05:09 PM
Can you move a car with the starter?
by atikovi - 01/19/20 04:49 PM
Leaf spring advice.
by mpack88 - 01/19/20 02:19 PM
Detroit 4-53T swap update.
by A310 - 01/19/20 12:54 PM
Wiper arm tension...
by Loogie - 01/19/20 12:26 PM
Changing Battery
by Char Baby - 01/19/20 12:16 PM
UOA shelf life
by STIcandy - 01/19/20 12:02 PM
2015 Ram Engine Oil
by nemtulea - 01/19/20 12:02 PM
Fram TG7317 1000 miles
by KenshinHimura - 01/19/20 11:57 AM
2013 Escape 2.0 Ecoboost surge
by HoosierJeeper - 01/19/20 10:36 AM
European Tools via Amazon - New Lug Wrench
by JHZR2 - 01/19/20 09:57 AM
Samsung 32 inch 4K curved monitor at Costco
by Cujet - 01/19/20 09:55 AM
2009 corolla 1.8
by Bettez88 - 01/19/20 09:41 AM
Remote key - OEM vs aftermarket
by AZjeff - 01/19/20 08:13 AM
Toyota Tundra Warranty
by Tundra73 - 01/19/20 08:10 AM
Thetarmac, lbstyling, tanpw, JPz521l, KirklanC
70481 Registered Users
114 registered members (AC1DD, 53' Stude, 3Aone, 2015_PSD, Aero540T, A310, 12 invisible), 3,126 guests, and 23 spiders.
Topics300,326
Posts5,173,355
Members70,481
Most Online3,825
Jan 19th, 2020
Here's a good Question... #3849840 09/10/15 09:43 PM
R
Rockrz Offline OP
R
I know someone that has an older vehicle with about 170k on it that runs perfectly. Plugs are dry when pulled and inspected and the engine (GM) has plenty of power so it makes no sense to do a reman engine really at this point.
But, the rear main has recently started to leak a little. They change the oil every 5k and have to add a quart every 3k or so. They have been running Amsoil (since about 75k) like I do on mine and the thought has come up that maybe the Amsoil is so clean that it contributed to the seepage.
So, I think they are going to try some Bar's Leak or something similar to see if that helps the rear main to stop leaking.
So, what's the general consensus on continuing to use Amsoil in this situation?
Think it would be better to keep using it, or switch to a conventional oil?
Just curious what the local oil experts here on the board recommend.
Re: Here's a good Question... [Re: Rockrz] #3849848 09/10/15 09:52 PM
H
HangFire Online Content
Online Content
H
Try a high mileage oil. Stay away from Bar's Leak.
Various musings: http://hangfire.net
Re: Here's a good Question... [Re: Rockrz] #3849850 09/10/15 09:53 PM
dlundblad Offline
Personally, I would ditch the additive and use a high mileage oil.
Mobil 1 HM or Pennzoil HM would be my personal choices. Others here have had great experience with Valvoline Maxlife blend.
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 195k M1 0w40 Mahle OX149D
97 Chvy Blazer 4.3 158k M1 EP 10w30 Supertech ST3980
Re: Here's a good Question... [Re: Rockrz] #3849865 09/10/15 10:05 PM
R
Rockrz Offline OP
R
I've talked to a few folks over the years that claim to have had good results using Bar's Leak. Isn't this stuff supposed to swell the seals a little?
Isn't Mobil 1 high Mileage still using a synthetic?
It's a V6 so what would work best, an 10W30?
Re: Here's a good Question... [Re: Rockrz] #3849872 09/10/15 10:13 PM
CT8 Offline
5,000 miles with Amsoil?
2015 F150 2.7
2018 F350 6.2
Re: Here's a good Question... [Re: Rockrz] #3849876 09/10/15 10:17 PM
B
Brybo86 Offline
B
Which car and engine, is it difficult to just change the rear seal?
12 Honda Odyssey 112k
09 Kymco Super8
08 Honda Accord 2.4L 164k
01 Kymco People 50
95 Yamaha Jog
Re: Here's a good Question... [Re: Rockrz] #3849880 09/10/15 10:19 PM
R
Rockrz Offline OP
R
They say the transmission needs to be removed in order to do a rear main seal which is going to cost a lot.
Re: Here's a good Question... [Re: Rockrz] #3849916 09/10/15 10:59 PM
R
ryanschillinger Offline
R
Try a high mileage oil for a couple OCI and see if it reduces or stops the leak. The problem isn't that the oil is synthetic, but he seal might have shrunk some over time. High mileage oil has conditioners that help keep seals working. My old Camry had 307k when I sold it. It had several very minor oil leaks. I used some Mobil HM oil for 2 consecutive oil changes and it very noticeably reduced the amount of oil used between changes.
2017 Subaru Forester
2014 Toyota Prius V
1969 Ford LTD
2014 Honda CB1100
Re: Here's a good Question... [Re: Rockrz] #3849921 09/10/15 11:04 PM
B
Branson304 Offline
B
Since the oil leak is fairly minor, I'd suggest switching to a high mileage oil. High mileage oils have special additives to recondition & swell the oil seals & gaskets in the motor. I'd suggest Valvoline MaxLife Synthetic Blend. Mobil 1 Full Synthetic High Mileage is my second pick. Valvoline also makes a MaxLife full synthetic but it's extremely difficult to find in my area. Anyway, these oils will help reduce the oil leak and maybe even stop it completely after while.
I don't suggest using any additives like Bar's Leaks. I don't figure it would do any harm, but a good high mileage oil would be best in my opinion.
Re: Here's a good Question... [Re: Rockrz] #3849924 09/10/15 11:07 PM
R
Rockrz Offline OP
R
OK, so apparently the high mileage oil contains additives that conditions the seals right?
Seems like they could use the Amsoil and just dump some additive in.
Question is, what additive does Mobil 1 put in their oil?
Do they sell a stand alone additive?
And, what would be wrong with using Castrol GTX High- Mileage?
Lots of folks like Caster oil
Re: Here's a good Question... [Re: Rockrz] #3849929 09/10/15 11:28 PM
R
Rockrz Offline OP
R
Doesn't Amsoil make a high mileage oil that has special additive to condition seals?
Re: Here's a good Question... [Re: CT8] #3850009 09/11/15 04:33 AM
K
Kuato Offline
K
Right! Unless it is a short tripper the oilcould go much further, even if it is not SS.
As far as the seal, 1 quart in 3000 miles isn't much so just drive it....get the seal fixed if it is worrisome, but adding something to clog the leaky seal only masks the problem and won't cure it. A HM oil might fix it but if it doesn't he is right back where he started as well as having switched away from his chosen oil.
Thick vs Thin test: 15k / 43k miles complete
Re: Here's a good Question... [Re: Kuato] #3850156 09/11/15 07:44 AM
Z
zuluplus30 Offline
Z
Seals wear out. Plain and simple. Amsoil or conventional, it's just going to happen at some point. I do agree 1q every 3k is minimal and echo the HM oil recommendations.
Re: Here's a good Question... [Re: Rockrz] #3850160 09/11/15 07:46 AM
H
HerrStig Offline
H
Check the PCV system.
Re: Here's a good Question... [Re: Rockrz] #3850623 09/11/15 02:35 PM
B
Brybo86 Offline
B
Once again please
Year, make , model and engine
09 Kymco Super8
01 Kymco People 50
95 Yamaha Jog
