Amsoil ASM 0w-20; 9,538 miles, '07 Accord 91,795
Ohio
Here is my sample of Amsoil SS 0w-20, one year in service. 80% Hwy/20% city. MM light calls for oil change around 6000 miles (it assumes conventional 5w-20). This was with a Fram Ultra filter. This oil does a nice job with my one year interval but I have changed out to M1 EP 0w-20 with M1 filter simply due to it being 1/2 the cost. I do not plan on trying to go longer than a 1 year OCI. This time next year we will see how M1 EP compares.
Code:
miles on oil 9,538 7,780 5,842 6,358 Universal
miles on unit 91,795 82,257 74,477 68,635 Averages
sample date 08/30/2015 08/26/14 10/26/13 03/10/13
make up oil added 1/2 1/3 0 0
OIL Type ASM 0w-20 ASM 0w-20 MC 5w-20 HG 5w-20
Aluminum 3 3 2 2 4
chromium 0 0 0 0 0
iron 6 6 4 5 9
copper 1 1 2 2 2
lead 0 0 1 0 1
tin 0 0 0 0 1
molybdenum 135 116 23 43 75
nickel 0 0 0 0 0
manganese 1 1 1 0 1
silver 0 0 0 0 0
titanium 0 0 0 0 1
potassium 1 8 0 4 3
boron 64 74 49 3 47
silicon 18 19 15 9 13
sodium 15 8 0 3 46
calcium 3387 3434 2283 2192 2127
magnesium 11 16 12 14 165
phosphorus 592 676 760 688 689
zinc 729 770 794 799 812
barium 0 0 0 0 0
SUS viscosity @210F 54.8 53.9 48.2 49.5
cSt viscosity @100C 8.70 8.45 6.72 7.12
Flashpoint 350 430 380 375
Fuel % 1.8
Antifreeze % 0.0 0.0 0.0 0.0
Water % 0.0 0.0 0.0 0.0
Insolubles % 0.2 0.2 0.3 0.3
TBN 3.3 4.2
TAN
Try a valve clearance adjustment - you're getting near the milestone at which it is due.
Originally Posted By: R80RS
What's going on with fuel?
Normally this car does not do a lot of short tripping but there were a lot for the last few weeks leading up to the sample date. In some cases it was turned on just to move its position in the driveway. I assume this is the reason for the increase in fuel.
Maybe just need to take it for a long drive before sampling? If it had a lot of idling before sampling that would increase the fuel numbers.
The wear numbers are excellent. TBN is still decent. Viscosity is good. I would not hesitate to run this oil again in your Accord. You could probably run it another 2-4K on top of this.
Even so, 1.8% seems high. Worth keeping an eye on this. The rest of it looks good though.
