- Joined
- Dec 30, 2006
- Messages
- 29,558
GM now specs 15W50 if tracked or raced. You'd mentioned tacking your car to the track twice.
Are you just parroting information that applies to C7's...or do you actually have a document that shows this as GM approved for a '06 Z06?
Here's some Z06 discussion:
http://www.corvetteforum.com/forums/c7-z06-discussion/3586726-15w-50-oil-for-track-events.html
You do realize you're linking to a C7 Z06 discussion, right? As I said before:
"Are you just parroting information that applies to C7's...or do you actually have a document that shows this as GM approved for a '06 Z06?"
Originally Posted By: Dirty_Howie
Here are some clarifications to questions asked.
I'll do the same. Listen, DH:
1. Go to Walmart.
2. Get Castrol Edge 5w-30 and Fram XG10060.
3. Run for same mileage as you've been doing, and get another analysis.
4. Report back with the results.
Why Castrol Edge? Isn't Mobil 1 what GM spec'd for the 2006 Corvette? Do you have any documentation from GM requiring the use of Castrol Edge?
1. Go to Walmart.
