Autozone $7 Coupon
by TheLawnRanger. 06/17/19 10:00 PM
5W20 Pennzoil Platinum vs. Pennzoil Ultra Platinum
by DrivinWest. 06/17/19 09:30 PM
Taillights cloudy (never)?
by WhizkidTN. 06/17/19 09:26 PM
2017 Silverado Front Bumper & Skid Plate??
by Mr_Joe. 06/17/19 09:20 PM
AC Issues - 2007 Chrysler Pacifica
by 92saturnsl2. 06/17/19 08:33 PM
Harbor Freight 4x8 Trailer $250
by FordBroncoVWJeta. 06/17/19 07:57 PM
Iron Butt Rally 2019
by Jarlaxle. 06/17/19 07:13 PM
Champion oil filters $1.34 at Rock Auto
by wemay. 06/17/19 07:12 PM
Stumped on which tire direction to go
by Pat in Speedway. 06/17/19 06:44 PM
Dealer Invoice, Hold Back, and Factory Incentives
by LoneRanger. 06/17/19 05:46 PM
HF Recall on 14" Electric Chainsaw
by SubLGT. 06/17/19 05:34 PM
Does the GM G80 need LS fluid?
by K20FA5. 06/17/19 05:07 PM
Pink Seats LS430
by Gebo. 06/17/19 04:58 PM
No 5w20 A5/B5 oil?
by SlavaB. 06/17/19 04:51 PM
Dexos2 for GTDI engines (EcoBoost, GM, etc)
by metroplex. 06/17/19 04:36 PM
GM X-Cars
by GumbyJarvis. 06/17/19 04:21 PM
Do downstream O2 ever get poisoned?
by PandaBear. 06/17/19 03:51 PM
Sharing files
by Chester11. 06/17/19 03:25 PM
Fumoto valves
by cwilliamsws6. 06/17/19 03:12 PM
PublicStellar, vacant, TallTravel, MrTire, Skraeling
68422 Registered Users
75 registered members (ajchien, alphadog, 1WildPig, AndyB, AC1DD, alcyon, 10 invisible), 1,653 guests, and 32 spiders.
Topics290,596
Posts4,989,181
Members68,422
Most Online2,967
Mar 10th, 2019
Page 1 of 22 1 2 22
Check UOA on my Corvette: High Lead #3843371
09/05/15 12:37 AM
09/05/15 12:37 AM
Calif
Dirty_Howie Offline OP
Calif
Car is a 2006 Corvette Z06. I bought it from an old geezer (older than me!). So it wasn't abused. Been putting Redline 5w30 in every 4k miles. Car is a daily driver with 2 Auto Cross days (car would be driven harder on a canyon cruise)
Car uses about 1/3 of a guart every oil change which is pretty good in my experience. The oil pressure is unchanged and very good since I took ownership.
Please give me your input on the lead content !!!
cheers
DH
Corvette UA0 with Redline 5w30: High Lead #3843373
09/05/15 12:45 AM
09/05/15 12:45 AM
Calif
Calif
Also whats up with the fluctuating Magnesium ??
cheers
DH
Re: Check UOA on my Corvette: High Lead [Re: Dirty_Howie] #3843376
09/05/15 12:51 AM
09/05/15 12:51 AM
NY
Benito Offline
Benito  Offline
NY
Redline 5w30 has virgin viscosity at 100c of 11.9cst, HTHSv of 3.7 and NOACK of 6%.
Blackstone didn't seem to realize this.
While your lead is higher than universal averages, your iron is lower.
Maybe change oil. What do GM say you should use? Isn't it M1?
That would certainly get your iron in line with the universal average. hide grin2
“You may not control all the events that happen to you, but you can decide not to be reduced by them.” - Maya Angelou
Re: Corvette UA0 with Redline 5w30: High Lead [Re: Dirty_Howie] #3843383
09/05/15 01:30 AM
09/05/15 01:30 AM
Toronto, Canada
HKPolice Offline
HKPolice  Offline
Toronto, Canada
Looks like main bearing or cam bearing wear. Both contain copper & lead underneath a steel coating. Most likely cam wear because LS engines are known to chew up cams. Worn cam bearings won't cause extra oil consumption, it'll just wear the camshaft out over time.
I'd crack open the valve covers and take a look. If the cams look fine then main bearings = huge PITA.
Re: Check UOA on my Corvette: High Lead [Re: Dirty_Howie] #3843394
09/05/15 02:32 AM
09/05/15 02:32 AM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
The car might need a different viscosity or a different oil altogether.
Re: Check UOA on my Corvette: High Lead [Re: Dirty_Howie] #3843405
09/05/15 04:28 AM
09/05/15 04:28 AM
Austria
LubeLuke Offline
LubeLuke  Offline
Austria
Lead at 39ppm is not high.
When you get above 50 ppm then monitor. Above 100ppm indicates there MAY be a problem.
The same for Iron.
Re: Corvette UA0 with Redline 5w30: High Lead [Re: Dirty_Howie] #3843406
09/05/15 04:29 AM
09/05/15 04:29 AM
Jupiter, Florida
Cujet Offline
Cujet  Offline
Jupiter, Florida
I'd try the obvious. Try a more viscous oil. While it's impossible to predict where the lead is coming from, it could be from highly loaded bearings and insufficient viscosity.
A simple move to a more viscous oil of the same type and brand, followed by another UOA may be illuminating.
In years past, highly loaded CSB's performed very well on oils heavier than what you are using.
Your engine develops it's higher power through increased displacement. Creating higher bearing loads. a GM press release that says the pistons themselves are 482 grams and the rods are 464 grams. I don't know if they reciprocating weights are more than the LS3, but I suspect they are. This would also lead to increased bearing loads.
Re: Corvette UA0 with Redline 5w30: High Lead [Re: Dirty_Howie] #3843462
09/05/15 07:41 AM
09/05/15 07:41 AM
Paradise of Florida
Greasymechtech Offline
Paradise of Florida
http://www.lingenfelter.com/mm5/merchant...tegory_Code=C54
http://aviaid.com/shopsite_sc/store/html/access-z06-ls7.html
http://www.drysump.com/LS7%20Installation%20Instructions.htm
Redline is pretty thick and not skimping on additives.
Too ways to go thicker, thicker oil or cooler oil.
I'd try the later larger sump(GM 2009+ tank) or the LPE version above. I don't see the need for the A.R.E system. I would consider the pan trap/baffle from Aviad.
Try Redline 0w40.
What oil filter?
At what point should a lurker start posting :-)
Re: Check UOA on my Corvette: High Lead [Re: Dirty_Howie] #3843496
09/05/15 08:38 AM
09/05/15 08:38 AM
Montreal, QC, Canada
Falken Offline
Falken  Offline
After reading up just now that Pennzoil Ultra Platinum 0W40 has a NOACK of 13, I just can't recommend Pennzoil products anymore.
I would seriously pull out the Big Guns and go Amsoil SSO 0W40 for two OCIs and get another oil report.
http://www.amsoil.com/shop/by-product/mo...etic-motor-oil/
I just don't think Red Line is working out on your car. And yes I agree with others the 30wt might be too thin!
Falken - Draftsperson
2010 Honda Fit DX-A in Black
Current Fill: Formula 1 Synthetic 5W20 SN, Wix 57356 Oil Filter, ATF DW-1
Re: Corvette UA0 with Redline 5w30: High Lead [Re: Dirty_Howie] #3843499
09/05/15 08:40 AM
09/05/15 08:40 AM
Tennessee
chrly919 Offline
chrly919  Offline
Tennessee
What's wrong with using what GM specs; Mobil 1 5W30? I use that in my 93 LT1 and my 2001 LS1. It's a LOT cheaper than Redline at Walmart. You can't check 'cams' bearings by removing the valve covers. There's only one cam, it's in the block. Never heard of them chewing up bearings.
99 Honda CRV AWD 250k
PHM 5w30 Purolator PureOne
14 Jeep G Cherokee Limited
93 Corvette coupe M1 5w30
01 Corvette coupe M1 5w30
Re: Corvette UA0 with Redline 5w30: High Lead [Re: chrly919] #3843544
09/05/15 09:30 AM
09/05/15 09:30 AM
Kentucky
Ramblejam Offline
Ramblejam  Offline
Kentucky
In the land of BiTOG, where every single PPM matters, other oils have consistently shown lower wear numbers in GM small-blocks. Red Line is not one of those, however.
Re: Corvette UA0 with Redline 5w30: High Lead [Re: Dirty_Howie] #3843553
09/05/15 09:48 AM
09/05/15 09:48 AM
Herndon, VA
btanchors Offline
btanchors  Offline
Herndon, VA
Dirty:
I don't know a thing about Corvettes, so I cannot speak to the lead content. But you also asked about the magnesium. I'm pretty sure this is from a prior oil that had significant amounts of magnesium in its additive package. For some reason, magnesium is one of those additives that takes several OCIs to completely "wash out" of the engine. The fact that it is progressively lower with each UOA shows this.
Re: Corvette UA0 with Redline 5w30: High Lead [Re: Cujet] #3843556
09/05/15 09:55 AM
09/05/15 09:55 AM
Dallas,Tx USA
aquariuscsm Online content
aquariuscsm  Online Content
Dallas,Tx USA
^^This. GM now specs 15W50 if tracked or raced. You'd mentioned tacking your car to the track twice.
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Re: Corvette UA0 with Redline 5w30: High Lead [Re: chrly919] #3843802
09/05/15 03:23 PM
09/05/15 03:23 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
That's fine if you're just driving your car to the grocery store at 35 mph, but this guy is racing his Corvette.
Re: Corvette UA0 with Redline 5w30: High Lead [Re: aquariuscsm] #3843818
09/05/15 03:42 PM
09/05/15 03:42 PM
Kentucky
Ramblejam Offline
Ramblejam  Offline
Kentucky
Are you just parroting information that applies to C7's...or do you actually have a document that shows this as GM approved for a '06 Z06?
Page 1 of 22 1 2 22
