2013 FX4 repair.
by marine65 - 02/17/20 07:36 PM
Ryan Newman
by P10crew - 02/17/20 07:26 PM
New gaming build shutting down on Metro 2033
by Cujet - 02/17/20 07:09 PM
Snapon
by P10crew - 02/17/20 06:51 PM
Conventional or Synthetic
by charmer37 - 02/17/20 06:49 PM
Jeep Wrangler 3.0L Diesel
by HighbrowHillbill - 02/17/20 06:36 PM
94 B4000 overheat Eureka
by HyundaiAbuser - 02/17/20 05:48 PM
PP Euro 5w40 SN Plus formulation VOA
by BurntMusic - 02/17/20 04:35 PM
Bicycle Shops
by CourierDriver - 02/17/20 04:26 PM
EBC Brakes
by hatt - 02/17/20 04:17 PM
Dream Car
by MrQuackers - 02/17/20 04:06 PM
What are people using now for outdoor antennas?
by BAJA_05 - 02/17/20 02:49 PM
3.0L TDI
by Shorthorn - 02/17/20 02:48 PM
Mountain Bike Whee/Tire Sizes!
by jcartwright99 - 02/17/20 02:21 PM
Found this old Fram XG8A on eBay
by blufeb95 - 02/17/20 01:54 PM
2005 Civic Horn Replacement
by cb450sc - 02/17/20 01:51 PM
QS Conv vs. QS HM vs. PYB
by Fordiesel69 - 02/17/20 01:09 PM
Tgarst, Predator35001819, Markapuu, jds59, JimMorrison
70728 Registered Users
131 registered members (antonmnster, 2010Civic, 55hambone, Anthony, 5AcresAndAFool, AC1DD, 16 invisible), 2,332 guests, and 23 spiders.
Topics301,586
Posts5,198,530
Members70,728
Page 1 of 23 1 2 23
Check UOA on my Corvette: High Lead #3843371 09/04/15 11:37 PM
Dirty_Howie Offline OP
Car is a 2006 Corvette Z06. I bought it from an old geezer (older than me!). So it wasn't abused. Been putting Redline 5w30 in every 4k miles. Car is a daily driver with 2 Auto Cross days (car would be driven harder on a canyon cruise)
Car uses about 1/3 of a guart every oil change which is pretty good in my experience. The oil pressure is unchanged and very good since I took ownership.
Please give me your input on the lead content !!!
cheers
DH
Corvette UA0 with Redline 5w30: High Lead #3843373 09/04/15 11:45 PM
Also whats up with the fluctuating Magnesium ??
cheers
DH
Re: Check UOA on my Corvette: High Lead [Re: Dirty_Howie] #3843376 09/04/15 11:51 PM
B
Benito Offline
B
Redline 5w30 has virgin viscosity at 100c of 11.9cst, HTHSv of 3.7 and NOACK of 6%.
Blackstone didn't seem to realize this.
While your lead is higher than universal averages, your iron is lower.
Maybe change oil. What do GM say you should use? Isn't it M1?
That would certainly get your iron in line with the universal average. hide grin2
Re: Corvette UA0 with Redline 5w30: High Lead [Re: Dirty_Howie] #3843383 09/05/15 12:30 AM
H
HKPolice Offline
H
Looks like main bearing or cam bearing wear. Both contain copper & lead underneath a steel coating. Most likely cam wear because LS engines are known to chew up cams. Worn cam bearings won't cause extra oil consumption, it'll just wear the camshaft out over time.
I'd crack open the valve covers and take a look. If the cams look fine then main bearings = huge PITA.
Re: Check UOA on my Corvette: High Lead [Re: Dirty_Howie] #3843394 09/05/15 01:32 AM
M
Merkava_4 Offline
M
The car might need a different viscosity or a different oil altogether.
Re: Check UOA on my Corvette: High Lead [Re: Dirty_Howie] #3843405 09/05/15 03:28 AM
L
LubeLuke Offline
L
Lead at 39ppm is not high.
When you get above 50 ppm then monitor. Above 100ppm indicates there MAY be a problem.
The same for Iron.
Re: Corvette UA0 with Redline 5w30: High Lead [Re: Dirty_Howie] #3843406 09/05/15 03:29 AM
Cujet Offline
I'd try the obvious. Try a more viscous oil. While it's impossible to predict where the lead is coming from, it could be from highly loaded bearings and insufficient viscosity.
A simple move to a more viscous oil of the same type and brand, followed by another UOA may be illuminating.
In years past, highly loaded CSB's performed very well on oils heavier than what you are using.
Your engine develops it's higher power through increased displacement. Creating higher bearing loads. a GM press release that says the pistons themselves are 482 grams and the rods are 464 grams. I don't know if they reciprocating weights are more than the LS3, but I suspect they are. This would also lead to increased bearing loads.
Re: Corvette UA0 with Redline 5w30: High Lead [Re: Dirty_Howie] #3843462 09/05/15 06:41 AM
G
Greasymechtech Offline
G
http://www.lingenfelter.com/mm5/merchant...tegory_Code=C54
http://aviaid.com/shopsite_sc/store/html/access-z06-ls7.html
http://www.drysump.com/LS7%20Installation%20Instructions.htm
Redline is pretty thick and not skimping on additives.
Too ways to go thicker, thicker oil or cooler oil.
I'd try the later larger sump(GM 2009+ tank) or the LPE version above. I don't see the need for the A.R.E system. I would consider the pan trap/baffle from Aviad.
Try Redline 0w40.
What oil filter?
At what point should a lurker start posting :-)
Re: Check UOA on my Corvette: High Lead [Re: Dirty_Howie] #3843496 09/05/15 07:38 AM
F
Falken Offline
F
After reading up just now that Pennzoil Ultra Platinum 0W40 has a NOACK of 13, I just can't recommend Pennzoil products anymore.
I would seriously pull out the Big Guns and go Amsoil SSO 0W40 for two OCIs and get another oil report.
http://www.amsoil.com/shop/by-product/mo...etic-motor-oil/
I just don't think Red Line is working out on your car. And yes I agree with others the 30wt might be too thin!
Re: Corvette UA0 with Redline 5w30: High Lead [Re: Dirty_Howie] #3843499 09/05/15 07:40 AM
chrly919 Offline
What's wrong with using what GM specs; Mobil 1 5W30? I use that in my 93 LT1 and my 2001 LS1. It's a LOT cheaper than Redline at Walmart. You can't check 'cams' bearings by removing the valve covers. There's only one cam, it's in the block. Never heard of them chewing up bearings.
99 Honda CRV AWD 250k
PHM 5w30 Purolator PureOne
14 Jeep G Cherokee Limited
93 Corvette coupe M1 5w30
01 Corvette coupe M1 5w30
Re: Corvette UA0 with Redline 5w30: High Lead [Re: chrly919] #3843544 09/05/15 08:30 AM
R
Ramblejam Offline
R
In the land of BiTOG, where every single PPM matters, other oils have consistently shown lower wear numbers in GM small-blocks. Red Line is not one of those, however.
Re: Corvette UA0 with Redline 5w30: High Lead [Re: Dirty_Howie] #3843553 09/05/15 08:48 AM
B
btanchors Offline
B
Dirty:
I don't know a thing about Corvettes, so I cannot speak to the lead content. But you also asked about the magnesium. I'm pretty sure this is from a prior oil that had significant amounts of magnesium in its additive package. For some reason, magnesium is one of those additives that takes several OCIs to completely "wash out" of the engine. The fact that it is progressively lower with each UOA shows this.
Re: Corvette UA0 with Redline 5w30: High Lead [Re: Cujet] #3843556 09/05/15 08:55 AM
A
aquariuscsm Online Content
Online Content
A
^^This. GM now specs 15W50 if tracked or raced. You'd mentioned tacking your car to the track twice.
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Quaker State Ultimate Durability 0W20
Re: Corvette UA0 with Redline 5w30: High Lead [Re: chrly919] #3843802 09/05/15 02:23 PM
M
Merkava_4 Offline
M
That's fine if you're just driving your car to the grocery store at 35 mph, but this guy is racing his Corvette.
Re: Corvette UA0 with Redline 5w30: High Lead [Re: aquariuscsm] #3843818 09/05/15 02:42 PM
R
Ramblejam Offline
R
Are you just parroting information that applies to C7's...or do you actually have a document that shows this as GM approved for a '06 Z06?
Page 1 of 23 1 2 23
