Hello, I was going to change the transmission fluid in my 2002 accord with honda atf. The transmission has a slow 1-2 shift and recently its been getting worse. It takes literally 1-1.5 second to shift and it seems to have a slight flare before it gets into second. The rest of the gears feel fine going up or down. I am concerned the transmission is on its way out. It has 150,000 miles and its backed by the 4cyl. These honda transmissions are not known to be good. Anyway The honda fluid it kind of expensive and if i want to do a couple drain and refills i was looking for something cheaper. My concern is everyone says to only use honda atf. Does anyone use something other than honda atf? Have you experienced better shift quality? How long have you been using non honda atf? Thanks
