Originally Posted By: DoubleWasp
Use the ATF+4 for your power steering too. Leave the Supertech PS fluid on the shelf.
Consider the LF9028 Stratapore Filter.
Will do with the ATF+4 in the PS pump. I've used both in my other Dodge with no ill effects.
And I have considered the Stratapore...that's all I used to run in my 12V. That was until they came out with the Fram Ultra. Filter efficiency is supposedly slightly higher, and they are much easier to get ahold of. No driving to Cummins Southern Plains, or having to order online.
This is very true, but I've been using the Stratapore with the built in bypass filter. It takes out things that even my beloved FU can't touch.
The FU is a great deal though. $12 locally, where the Purolator Synthetic is literally double the price.
I have used the Fleetgaurd Venturi LF9028 (pretty sure that's the correct #) in my 12V in the past. But with the OCI I am currently using in that rig, I couldn't justify the price bump.
