M1 HM 10w-30 vs M1 FS 0w-40
by RDY4WAR. 03/20/19 10:04 PM
Need Recommendations For A New SUV
by Dwight_Frye. 03/20/19 08:50 PM
GE dishwasher clicking
by silverrat. 03/20/19 08:20 PM
Every 6 months or one year OCI
by asker123. 03/20/19 07:36 PM
Valu Home Ctr. Peak Oil $9.94/5 qt jugs
by Nickdfresh. 03/20/19 07:32 PM
Chemical fire in texas
by Fitter30. 03/20/19 07:09 PM
PZ 37 CUT OPEN
by 53' Stude. 03/20/19 06:42 PM
Lube Intervals
by NibbanaBanana. 03/20/19 06:41 PM
When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
FYI: Costco is now stocking the 'good' Techron
by mbz321. 03/20/19 12:32 PM
Auto maintenance advice from a locksmith?
by Variant_S. 03/20/19 12:18 PM
DarkFrontier, Zuraxus, Burks21, GG16v, fleetwood62
67572 Registered Users
74 registered members (ammolab, Aichiguy, 928, AndyB, AlaskaMike, 13 invisible), 1,541 guests, and 59 spiders.
Topics286,168
Posts4,903,484
Members67,572
Most Online2,967
Mar 10th, 2019
PP EURO LX 0W30 #3827896
08/20/15 10:54 AM
08/20/15 10:54 AM
Southern Ontario
21Rouge Offline OP
21Rouge  Offline OP
Southern Ontario
Pennzoil Platinum EURO LX SAE 0W30 can be used for modern European Diesel Engines with particulate filters as well as modern European gasoline engines.
(This is not an ESSO Oil as listed in the VOA shown below).
The VI index implied by the #s is 200 which is quite close to the official TDS of 204.
TDS for PP 0W30 EURO
The TBN seems to be quite low...lower than the "Pennzoil Team" has posted elsewhere on-line.
Re: PP EURO LX 0W30 [Re: 21Rouge] #3828102
08/20/15 01:43 PM
08/20/15 01:43 PM
Burlington, Ontario, Canada
CATERHAM Offline
CATERHAM  Offline
Doug, thanks again for getting a VOA on this new interesting oil. Yes I know I dug up the Lab (ALS) to use in my home town that could provide a reasonable price including KV40 and TBN but you mailed in the sample and paid for the analysis.
The viscosity measures are very close to the published PDS figures although both are a bit lower particularly the KV100 value hence the marginally lower calculated VI of 200 vs 204.
Assuming the lab's figures are spot on then this oil has been slightly under additized in terms of VIIs.
Regardless, it's now confirmed PP Euro LX 0W-30 is the only 200 VI commercially available 30 grade motor oil.
I had hoped the Phos' level of 719 ppm would have come in closer to the 800 ppm limit being a diesel oil but is typical of a fuel conserving SN 30 grade.
Nice to see the high 383 Boron level.
Looking forward to the first UOA to see how it holds up in service.
-'74 Lotus Europa, 5W-50 & VSOT
-'96 BMW 328i, 50/50 TGMO 0W-20/M1 0W-40
-'94 Caterham 7, FUCHS 0W-20
-'18 Tesla Model 3 - FF diff' oil
Re: PP EURO LX 0W30 [Re: 21Rouge] #3828353
08/20/15 06:26 PM
08/20/15 06:26 PM
Pennsylbammyvania
dailydriver Offline
dailydriver  Offline
Pennsylbammyvania
Yes, the boron level is GREAT, but then I guess it needs something to make up for the lack of moly.
I am also interested in it's TBN retention, for IF it is decent (despite the low starting TBN), I would also go through the effort to find/purchase this product, and use it for the winter OCI. wink
2016 Ford Fiesta ST 14K miles
Ravenol DXG 5W-30
Amsoil Ea15K51 filter
Ravenol MTF-2 in the IB6 transaxle
Re: PP EURO LX 0W30 [Re: dailydriver] #3828988
08/21/15 11:12 AM
08/21/15 11:12 AM
Hampshire, UK
Joe90_guy Offline
Joe90_guy  Offline
Hampshire, UK
Just my opinion of course, but having boron in an oil isn't such a good thing. As often as not, the boron comes from boric acid which is used in the of post-treatment of ashless dispersants to make them more seal friendly. Sadly, it makes the dispersants less good at at carrying out their primary function. A lot of boron probably means a lot of ashless which is also a double edged sword.
Re: PP EURO LX 0W30 [Re: Joe90_guy] #3875309
10/05/15 05:09 AM
10/05/15 05:09 AM
Malaysia
zeng Offline
zeng  Offline
Malaysia
Unaware of 'ill' effects of high Boron , though . confused
Note:I know it's an old thread.
Re: PP EURO LX 0W30 [Re: 21Rouge] #3876234
10/05/15 09:49 PM
10/05/15 09:49 PM
Pennsylbammyvania
dailydriver Offline
dailydriver  Offline
Pennsylbammyvania
Does anyone have any idea what the actual HTHSV of this product is (NOT just an < or > 3,5 type of spec)?? shrug
Ravenol DXG 5W-30
Re: PP EURO LX 0W30 [Re: dailydriver] #3876430
10/06/15 05:17 AM
10/06/15 05:17 AM
'Stralia
Shannow Online content
Shannow  Online Content
'Stralia
As they claim C2/C3, and the fuel economy of the oil, it would have to be as close to 3.5 as makes no difference.
According to member bobbydavro here, in the 5W40 Castrol thread
it can't be much more than 3.5.
A couple of 5W30s as examples
* Edge 5W30 A3/B4 claims 3.6
* Nulon with their Euro 5W30 claimed ACEA A3/B4, and A5/B5, and that by formulating to "exactly" 3.5 they got both.
Chevron 15W30 is 3.7, which would IMO set an upper bound for the oil in question.
And the 0W40s are 3.7-3.8 typically.
So we can confidently set the lower bound at 3.5, and predict that it's not going to be 3.7 or above.
I'm narrowing it to 3.5-3.6, erring on the short end.
I know it's not the number, but if they aren't telling fibs, logic would dictate that it's barely over 3.5.
Re: PP EURO LX 0W30 [Re: 21Rouge] #3877503
10/06/15 10:51 PM
10/06/15 10:51 PM
Pennsylbammyvania
dailydriver Offline
dailydriver  Offline
Pennsylbammyvania
Yes, I should have known it would be that high, being labelled as a 'Euro' oil, and having to meet said specs. frown
May have to re-think using this as a winter OCI oil, as I would prefer something in the 3.0-3.3 HTHSV range.
Ravenol DXG 5W-30
Re: PP EURO LX 0W30 [Re: dailydriver] #3877632
10/07/15 05:39 AM
10/07/15 05:39 AM
'Stralia
'Stralia
Give it a crack, I reckon.
I assume it's replacing your blend, so doing the mixing calculator, the KV's comparable to what you are running, and the high VI will probably make it a wash, or give the Pennz a (tiny) KV edge at cold temps.
I reckon that it won't take long for the HTHS to be at 3.3. smile
Re: PP EURO LX 0W30 [Re: 21Rouge] #3878201
10/07/15 05:16 PM
10/07/15 05:16 PM
Pennsylbammyvania
dailydriver Offline
dailydriver  Offline
Pennsylbammyvania
Yeah, IF I can get Summit Racing to start carrying this stuff (or can find it anywhere closer than 100 miles away at a SOPUS distributor), I might just do that, since the only other straight, no mix/blend, decent VI, 0W-30 I wanted to try, (the RLI product) has an even higher yet HTHSV; I think it might even be a 3.8!? eek
(Even though the RLI spec sheet only states the SAE mandated > 2.9, could it even possibly be that high {3.8}, IF the claimed cSt @ 100*C is only 11.3??)
Ravenol DXG 5W-30
Re: PP EURO LX 0W30 [Re: dailydriver] #3878588
10/08/15 04:08 AM
10/08/15 04:08 AM
'Stralia
'Stralia
RLI Biosyn Extra ?
Doing some rudimentary math...
Using the Operational Viscosity Calculator...KV150 would be 5cst.
Using the density calculator, [email protected] would be 784Kg/m^3.
IF it were Newtonian, the HTHS would be .785*5, or 3.9cst.
Straight Vege oils can be ridiculously high VI, and Newtonian.
It's cold behaviour doesn't look newtonian, so something has likely been lost/added in the "stablilisation"
If you assume the 80% shear stability of the ultra high VI 0W20s, you get an HTHS of 3.1...but I doubt that's the case.
Assume 90% SSI, yo get 3.5.
I'm betting, not promising, that the RLI is probably at least 3.5 as well, and possibly a bit higher.
Again, just mathwork, and not a promise.
Re: PP EURO LX 0W30 [Re: 21Rouge] #3881510
10/10/15 09:27 PM
10/10/15 09:27 PM
Pennsylbammyvania
dailydriver Offline
dailydriver  Offline
Pennsylbammyvania
Thanks Shannow. thumbsup
Yes, 3.9 cSt (or even just over 3.5) with minimal possibility of shear is just too thick for my app in the winter here, as I might as well just use one of the thinner, 3.7-3.8 cSt (and more readily available) 0W-40s instead.
I am going to try and get a hold of this PennzPlat Euro LX 0W-30.
Ravenol DXG 5W-30
Re: PP EURO LX 0W30 [Re: dailydriver] #3881741
10/11/15 04:34 AM
10/11/15 04:34 AM
'Stralia
'Stralia
Cool, I like the plan, and would like to see what results you get.
Re: PP EURO LX 0W30 [Re: 21Rouge] #4176552
08/13/16 11:32 PM
08/13/16 11:32 PM
Canada
addyguy Offline
addyguy  Offline
Canada
To bump this thread...in Canada, Canadian Tire now carries this oil in 1-liter bottles for $10.49 each.
2010 Kia Soul 2U - 2.0L I-4, auto; 141k miles.
M1 EP 10W-30; OEM Kia filter.
Re: PP EURO LX 0W30 [Re: addyguy] #4178379
08/15/16 08:02 PM
08/15/16 08:02 PM
pa
benjy Online content
benjy  Online Content
pa
i read that if an oil has a high VI but average or less HTHS it uses a LOT of viscosity improvers! i read + continue to learn, but so much info is outdated quickly
