I work in the maintenance department for a John Deere factory and almost everyone in the maintenance department and a few other departments have tx gators or cx gators. We get new gator yearly and they get used very hard. Most of them get 200 to 300 hours with some getting tripple that on the factory fill with it never even being checked to see if they still have oil in them. We never have issues with them aside from the occasional transmission or carburetor issues. Almost all of these are severely overloaded. When we get the new ones no one goes easy on them till they are broken in. They just the the peddal slammed to the floor till you have to slam on the brakes.
I have gotten three new gators since I have been working here and here is what I have found works best to break them in to obtain full power and not consume oil. When these are new they are very gutless and the brakes don't work the best. On the cx gators that have a 8.5 hp single cylinder Kawasaki motor the best way is to reach down behind the seat and grab the govoner arm and pull it wide open for a few hundred feet. Then we run them as hard as you can and the will come around in about a day or two. If you don't do this they run like [censored] and die a lot. On the tx gators with a 15.5 hp v-twin Kawasaki you have to for it then slam on the brakes repeatedly then let it cool down for a bit and it will be good to go. You can always tell when you get on a gator that has been driven by management as they will be slugish and slow even with 100 hours on them. They just don't break in right without a good load.
I know this goes against what everyone says you should do to break engines in but we have no issues with it. The gators never use oil even with the factory fill and never have mechanical issues.
