Pictures of welds. Yeah thats right.
Those are some impressive welds.
Yes, quite. His work would have more than likely been done on a welding turn table to get work that nice and consistent.
I used to work for a large scale filter manufacturer and we'd get stainless steel pipe assemblies in with that caliber of welding done.
Had one guy work with us for a while that could weld that well- he showed me how it's done, and while I'm good, I'm not that good!
I worked for 11 yrs in a shipyard. Welding is definitely an art and good fabrication looks pretty too. " Like a row of dimes" I heard a welding boss describe one lady welder's work.
Reminds me of an article I read where a company that was tasked with digitizing the design of the F-1 rocket engine made comments about the construction techniques from the 60s:
Quote:
"Because they didn't have the analytical tools we have today for minimizing weight, everything was very robust," noted Betts, when I asked what they found as they tore down the engine. "That's apparent in really every aspect of the engine. The welds—"
"Oh, the welds!" interrupted Case. "The welds on this engine are just a work of art, and everything on here was welded." The admiration in his voice was obvious. "Today, we look at ways of reducing that, but that was something I picked up on from this engine: just how many welds there were, and how great they looked."
"You look at a weld that takes a day," he continued, "and there are thousands of them. And these guys were pumping engines out every two months. It's amazing what they could do back then and all the touch labor it took."
"One thing I notice when I look back at older engines," commented Coates, the senior engineer, "was just like Nick and Erin were alluding to: the complexity of the welds. You didn't have the kind of advanced manufacturing we had today, so quite honestly, these were hand-made machines. They were sewn together with arc welders, and it's pretty amazing to see how smooth and elegant it came out. Today, you'd look at doing precision casting, not these thousands of welds."
Not that I am skeptical, but the consistent symmetry makes me think those welds are machine done. I took my calipers up to my computer screen and the pool beads are almost the same spacing.
Originally Posted By: Mr Nice
What about Xray test for structural integrated. Nice looking welds don't mean squat.
+1 - they are nice looking TIG welds, but (with no disrespect to the welder), nearly every TIG welder I ever worked with who was worth his salt could make stainless welds like that--especially with a N2 purge on the piping.
I have zero doubt those were made by hand and not machine. I have seen thousands of them back in the day when I worked in the petrochemical industry. Do a search for submerged arc welds and you can see some really symmetric and smooth welds.
Welding porn. That's some beautiful work.
Not the learning annex hack stuff I can pull off.
I was grinding down some big globs I let a wire machine and grandpa asked me what I was doing I told him grinding so my welds would look good.
His reply hilarious he said "I was a grinder - not a welder."
UD
What is more impressive than those welds are the drunken shaky burn outs that can do it with little effort severely hung over/still drunk. I have never seen a welder that didn't shake.
After thoudands of hours welding, your welds will look like a machine did it.
The fumes are toxic to your body so you have to be careful.
Most of those look amazing. The first looks a bit 'cool' to me. You need to have your tech knowledge first, but the art part follows. I did some gas welding repair long ago on an old fabric aircraft's structural tubing and it took me a couple hours to relearn and practice before getting at the task. While my work was strong enough, it wasn't quite as uniform or nearly as pretty as the true artists do..
These welds look good, but if I were doing that job I would not weave the beads that wide, especially the two beads showing on the pipe nipple fillet welds. The wider the bead the more heat inclusion the base metal receives. In some cases that is important.
I had some welding done by a guy moonlighting from Electric Boat. Those welds were nuclear submarine quality. Next best are the welds on BMW bike frames. Just compare them to the Japanese stuff.
Welders are a onery. Years ago I was fixing a forklift at an ice cream plant and their welder was welding up some stainless steel 4 inch pipe , I watched him weld for a few minutes and said to him wow that is an awesome weld! He turned to me and said CT8 I have been doing this or 25 years it better look good!
