Originally Posted By: MarkM66
Originally Posted By: andyd
Why are you doing this? If a bearing is worn enough to knock, chances are the journal is worn. Wabbout using a heavier oil? It is possible to do the job. I replaced #4 rod and piston on an over heated Datsun that had detonated through the piston crown. The journal was ok and I re-used the original rod bearing. Good luck
I'd like to know too. Seems like a major job for a band aid fix. Even if I were to do this, I almost think it'd be less labor overall to just remove the engine.
I'd rather run the engine to death, then rebuild.
I rolled new bearings into a 345 international after they were damaged when the oil pan got smashed. Got another 100k out of it before I sold it
