1977 2-stroke moped ESSO 2-T 18:1?
by N8conn - 11/11/19 08:50 PM
*NEW* DELO 600 ADF
by SavagePatch - 11/11/19 07:48 PM
2003 Ford CVPI, 96kmi, 10kmi on Pennz HM 5W30
by Colt45ws - 11/11/19 07:24 PM
Amsoil Upper Cylinder Lubricant
by Donald - 11/11/19 06:41 PM
Pfft.. piece of cake!
by Mad_Hatter - 11/11/19 06:17 PM
Garage door lack of signal/reception issue
by dja4260 - 11/11/19 06:05 PM
low voltage triggers abs and parking brake light?
by motor_oil_madman - 11/11/19 06:03 PM
Kendall GT-1 MAX 5W30 2017 Crosstrek
by Voleak - 11/11/19 05:51 PM
Wife’s Oil Change
by KevGuy - 11/11/19 05:48 PM
AZ $10 off of $50
by BlakeB - 11/11/19 05:41 PM
B&S riding mower long filter short filter etc.
by j_mac - 11/11/19 05:32 PM
Covering the cowl vent
by painfx - 11/11/19 05:31 PM
Project: DuckHead Arm
by RayCJ - 11/11/19 05:29 PM
I Found The Perfect Garage Door Oil
by billt460 - 11/11/19 02:03 PM
Oil recommended for Old Snowthrower
by Ckerch - 11/11/19 01:58 PM
Choo Choo train maintenance and repairs?
by Chris142 - 11/11/19 01:58 PM
Hemi Oil Use
by Zap1967 - 11/11/19 01:27 PM
Chizzle, greenmeanie, vw_sod, Mac87, LazyJ
69833 Registered Users
117 registered members (69Torino, 2000Trooper, 2002 Maxima SE, 87sammy, 2010Civic, 10WSmuckers, 10 invisible), 2,160 guests, and 19 spiders.
Topics297,287
Posts5,112,332
Members69,833
Most Online3,589
Nov 2nd, 2019
Mobil 1 ESP 5W30 Noack value? #3783232 07/07/15 10:33 PM
T
Tabnorup1976 Offline OP
T
I contact Mobil about the actual noack value of Mobil 1 ESP 5W30 and answer me that noack value is considered confidential. Do you know the value? Is the value from a dependable source?
Thanks!
Re: Mobil 1 ESP 5W30 Noack value? [Re: Tabnorup1976] #3783234 07/07/15 10:41 PM
Bandito440 Offline
Exxon-Mobil doesn't release NOACK numbers for any of their oils, or at least none that I've seen.
Contact Blackstone Labs. They might be able to test it for you.
Welcome to BITOG.
'14 Grand Cherokee EcoDiesel
Rotella T6 5w-40 & OEM filter
Re: Mobil 1 ESP 5W30 Noack value? [Re: Tabnorup1976] #3783284 07/08/15 12:42 AM
T
toyota62 Offline
T
Member FalconLS told
Me it is 5.6
Bob.
Re: Mobil 1 ESP 5W30 Noack value? [Re: Tabnorup1976] #3783364 07/08/15 05:42 AM
Q
Quattro Pete Offline
Q
Yes, 5.6%, as tested on a Russian oil site.
Is it a dependable source? I have no idea but that is the only piece of data we have.
Tabnorup1976, what is the reason for you needing to know the Noack value?
2002 530i   2015 Q5 3.0T   2018 Charger SRT
Re: Mobil 1 ESP 5W30 Noack value? [Re: Quattro Pete] #3783889 07/08/15 12:50 PM
V
volodymyr Offline
V
Quattro Pete,
I do understand russian, so I searched and yes, it is 5.6 % indeed as seen at http://www.oil-club.ru/forum/topic/6709-6709/
The oil-club.ru is as reputable as bobistheoilguy.com so it should be reliable.
2001 Honda CBR 600 F4i, Castrol Power 1 Racing 4T 10W40 (SM,MA2)
2010 Nissan Qashqai 2.0, Shell Helix Ultra 5W30 (A3/B4,MB 229.5,502.00/505.00)
Re: Mobil 1 ESP 5W30 Noack value? [Re: volodymyr] #3783916 07/08/15 01:17 PM
Q
Q
Yeah, I just don't know what lab they use. If it's anything like Blackstone that we have here in the US, it's not overly reliable. I mean, you can send a sample to three different labs and get three different results. smile
Granted, the lab that the Russian folks use is probably more advanced if they can test for Noack, CCS viscosity, sulfated ash, etc.
One thing you can be certain of is that this oil has Noack of no more than 10% based on the mfg specs it meets. That should be good enough for most folks. I'm not sure how much additional benefit you're getting by having it lower than that, but I guess the lower the better, but at some point the law of diminishing returns will catch up to you. smile
Re: Mobil 1 ESP 5W30 Noack value? [Re: Quattro Pete] #3783987 07/08/15 02:23 PM
E
edyvw Offline
E
It meets MB 229.51, good for me.
Let's say error is 3%, that still means 8.6% which is [censored] good.
15' Toyota Sienna AWD (Mobil1 5W30 EP+OEM filter).
11' VW Tiguan 2.0T (Castrol 0W40+MANN filter)
Re: Mobil 1 ESP 5W30 Noack value? [Re: edyvw] #3783992 07/08/15 02:26 PM
O
OVERKILL Online Content
Online Content
O
And quite close to M1 0w-40 @ 8.8%, which is also [censored] good wink
2016 Grand Cherokee SRT - Ravenol SSL 0w-40, FRAM Ultra
Re: Mobil 1 ESP 5W30 Noack value? [Re: OVERKILL] #3784070 07/08/15 03:09 PM
E
edyvw Offline
E
Of course.
I personally think that of all Low-SAPS oils, M1 5W30 ESP is by far THE best!
Re: Mobil 1 ESP 5W30 Noack value? [Re: Quattro Pete] #3784092 07/08/15 03:36 PM
V
volodymyr Offline
V
Quattro Pete,
I think the moderator of the web-site is using some lab he has a connections with because none of the result reports contain actually the name or the logo of the lab. Yes, I understand your concern, the lab may be no so reliable since it's name is unknown, no logo, etc.
Re: Mobil 1 ESP 5W30 Noack value? [Re: edyvw] #3784096 07/08/15 03:40 PM
V
volodymyr Offline
V
edyvw,
Ehh ... It's time for me to think about my next oil change (in 3 months) and I am having a hard time to find a good full saps oils in 5w-30 viscosity in Europe. We have, however, a plenty of Low SAPS here in 5W-30. And every time I think if I should switch to low saps oils from full saps. I even asked a few questions here on bitog and the bottom line is that full saps are better for engine wear protection.
Shall we discuss this once again? smile
Re: Mobil 1 ESP 5W30 Noack value? [Re: volodymyr] #3784109 07/08/15 03:58 PM
E
edyvw Offline
E
edyvw,
I personally think that when it comes to lubrication, there is no difference. However, Full-SAPS will keep TBN for longer period of time.
I mean, my brother racked up around 370,000km on his Peugeot 407 1.6hdi using Total MC3 5W30. He racked up 280,000km on his 525d E60, before it burned to the ground bcs dealer did not replace one wire that was on a recall. He was using genuine BMW LL-04. Now, he has 240,000km on his Peugeot 508 2.2hdi GT using only Total MC3 5W30.
I just got back from Bosnia, he has also Skoda Octavia 1.9TDI PD (105hp) and 180,000km. He bought that one new, and it is used for business by several people employed in his company. I took it to local mechanic that I am freind with for a long time, and my brother maintains vehicles at his place, he uses Repsol 5W30 VW 504.00/507.00. No oil consumption at all, car still hits 200km/h with no issues.
So, I would like for people who claim that low-saps provides less lubrication to tell me one thing: when will driver notice that issue?
Re: Mobil 1 ESP 5W30 Noack value? [Re: edyvw] #3784170 07/08/15 04:43 PM
Q
Q
Probably never.
Re: Mobil 1 ESP 5W30 Noack value? [Re: Quattro Pete] #3784176 07/08/15 04:44 PM
E
edyvw Offline
E
Probably never.
That is my point. Thanx.
