I'm going to do this for the first time. I just wanted to make sure I'm not confused on something even though this all seems simple enough. Also, I'm just looking to get the old coolant out, a simple one time flush with distilled water, and new coolant in. Nothing fancy. I also purchased a Lisle Spill-Free funnel after hearing such great things about how easy they make the bleeding process.
1) Drain radiator.
2) Remove lower radiator hose to drain block.
3) Fill radiator with distilled water.
4) Turn on car and wait until thermostat opens to cycle through engine (keep adding water while this takes place until full).
5) Drain radiator.
6) Remove lower radiator hose to drain block.
7) Fill radiator with coolant.
8) Turn on car and wait until thermostat opens to cycle through engine (keeping adding coolant while this takes place until full).
9) Wait for air to bleed out of system.
10) Profit.
My main question is whether removing the lower radiator hose will get most of the coolant/water out of the block?
1) Drain radiator.
5) Drain radiator.
10) Profit.
