Link
Quote:
We tested four of the top selling oils, two conventional and two synthetic, utilizing
a FALEX PIN and Vee-block tribometer at an independent analytical laboratory.
The Phillips Petroleum designed procedure used is a derivative of ASTM D-2670
and is described in the Scientific Journal “WEAR”. The procedure correlates
very well with camshaft wear in engines using gasoline and diesel engine oils.
The often-cited 4-Ball wear test does not correlate to engine wear.
Quote:
Modern commercial
engine oil formulations are at best a compromise due to government regulations
and costs. These constraints lead to reduced additive concentrations and
subsequently reduced performance.
CamGuard Automotive delivers uncompromised performance, using advanced
technology, to directly address the problems of wear, deposits and corrosion to
extend engine life of gasoline and diesel engines.
CamGuard Automotive reduces wear more than 80% using advanced anti-wear
additives that work synergistically with the standard zinc anti-wear used in passenger
car and diesel oils. It contains no phosphorus and it will not adversely affect
catalytic converters.CamGuard Automotive is particularly useful in older engine designs utilizing
flat tappet valve trains especially when using modern, mandated lower zinc
(phosphorus), oils.
CamGuard Automotive provides excellent anti wear protection, during “dry”
starts after periods of prolonged inactivity, by maintaining a residual active
film on critical parts.
CamGuard Automotive utilizes multiple antioxidants to preserve and prolong the
life of the zinc and phosphorus in the modern oils. They also prevent varnish formation
by decomposing reactive free radicals, from the blow-by fuel, which is particularly
important in high performance carbureted or fuel injected engines running “rich”
mixtures for maximum power.
CamGuard Automotive utilizes unique friction modifiers that reside in the high
temperature and heavily loaded areas of the engine to provide a measurable
increase in fuel economy.
CamGuard Automotive contains seal conditioners that nullify the effects of heat
and time to keep seals supple, flexible, and performing like new.
Quote:
Modern commercial
(phosphorus), oils.
