Originally Posted By: Robb.
Whats the top 3 brake fluids on the "easy to get" market ?
I heard ATE, AP racing and Amosil ?
https://www.lelandwest.com/brake-fluid-comparison-chart.cfm
Are you plan to use DOT-4 in your Civic's ? Are you track one or all yours ?
For normal daily driving DOT-4 isn't needed. Most European cars recommends DOT-4 with 2 year change interval, most Japanese cars use DOT-3 with 3 years change interval, even the higher performance S2000 recommends DOT-3.
I use generic DOT-3 in my E430 for almost 10 years now without any problem, the braking distance is about the same, only better performance tire would yield a shorter braking distance in panic stop from 60-70 MPH, which is rarely happen(once a year, may be) if you pay attention to surrounding traffic when you drive.
